Home » Eclipse Projects » EGit / JGit » SSH algorithm negotiation failed(Connecting from Egit to Github)
SSH algorithm negotiation failed [message #1720625] Tue, 19 January 2016 20:37 Go to next message
I am unable to push to Github from Eclipse 4.5.1 with an error of 'algorithm negotiation failed' and the server requesting the use of 'publickey'. I have verified that the URI is OK and that the correct public key has been installed on Github. I am at a loss to know what I should be looking at to try and resolve this problem
Re: SSH algorithm negotiation failed [message #1720665 is a reply to message #1720625] Wed, 20 January 2016 03:45 Go to previous messageGo to next message
Which protocol are you using (how does the URI look like)?
Re: SSH algorithm negotiation failed [message #1720666 is a reply to message #1720625] Wed, 20 January 2016 03:45 Go to previous messageGo to next message
Which protocol are you using (in other words: how does your URI look like)
Re: SSH algorithm negotiation failed [message #1720667 is a reply to message #1720665] Wed, 20 January 2016 03:47 Go to previous messageGo to next message
Which JGit and EGit version are you using ?
Find that under Help > Installation Details
If it's not 4.1.1 please upgrade to the latest release by pointing Help > Install new software...
to http://download.eclipse.org/egit/updates
Re: SSH algorithm negotiation failed [message #1720761 is a reply to message #1720665] Wed, 20 January 2016 12:14 Go to previous messageGo to next message
1. I am using Egit/Jgit version 4.1.1.
2. I am using the SSH protocol and my URI is ssh://github.com/jfgossage/Sabia
Re: SSH algorithm negotiation failed [message #1721773 is a reply to message #1720761] Fri, 29 January 2016 22:39 Go to previous messageGo to next message
Further information. I am running on Windows 0 and my local Git config file is the following:
[core]
symlinks = false
repositoryformatversion = 0
filemode = false
logallrefupdates = true
[branch "master"]
remote = origin
merge = refs/heads/master
[remote "origin"]
url = ssh://git@github.com/jfgossage/Sabia.git
Any help would be greatly appreciated as this has dragged on too long. Incidentally I can connect with Git on the command line so this appear to be specifically a Egit/Jgit problem.
Re: SSH algorithm negotiation failed [message #1721788 is a reply to message #1721773] Sat, 30 January 2016 09:31 Go to previous messageGo to next message
I have verified that this problem also exists on Ubuntu 15.10 with latest Eclipse so it would appear to probably be a configuration problem. I don't think it is a problem with the SSH keys as I can connect with other software.
Re: SSH algorithm negotiation failed [message #1721962 is a reply to message #1721788] Mon, 01 February 2016 16:34 Go to previous messageGo to next message
Check which version of com.jcraft.jsch you have installed, JGit is using this as a ssh client. If it's not 0.1.53 then try to ugprade to that version.
Maybe your ssh keys are using an algorithm not yet supported in your version of jsch. Find the details in jsch's change log
http://www.jcraft.com/jsch/ChangeLog
You can install com.jcraft.jsch 0.1.53 from http://download.eclipse.org/tools/orbit/downloads/drops/R20151221205849/repository/
If EGit doesn't come up after the upgrade start Eclipse with the -clean option (see https://bugs.eclipse.org/bugs/show_bug.cgi?id=478695)
Re: SSH algorithm negotiation failed [message #1721963 is a reply to message #1721962] Mon, 01 February 2016 16:36 Go to previous messageGo to next message
Try to load your private ssh key from Eclipse: click "Preferences > Network Connections > SSH2 > Key Management > Load Existing Key..."
and select the private key you use for Github, the corresponding public needs to be uploaded to your Github account.
Re: SSH algorithm negotiation failed [message #1721966 is a reply to message #1721963] Mon, 01 February 2016 17:13 Go to previous message
I had already done this before starting this exercise. The keys seem to be OK as I can access Github using SSH on Windows using the git command line package.
Previous Topic:Resetting a specific file
Next Topic:EGIT/GIT Eclipse contribution : difficulties with setup for 4.2.0 importing egit-developer-tools.p2
Current Time: Sat Jul 19 14:26:55 EDT 2025
Powered by FUDForum. Page generated in 0.05270 seconds
