Home » Eclipse Projects » Eclipse 4 » Making Eclipse with special configuration
Making Eclipse with special configuration [message #1720285] Fri, 15 January 2016 17:31 Go to next message
Hi every body,
I am new in eclipse worlth.
Now I have an eclipse with many plug-ins and other people who want to import my project should have all the plug-ins which I have. How could I have an eclipse with all the plug-ins which I have?
I don't want the other install these plug-ins but also an eclipse with all the plug-ins.
Re: Making Eclipse with special configuration [message #1720294 is a reply to message #1720285] Sat, 16 January 2016 02:38 Go to previous messageGo to next message
Nowadays you would use oomph and create a configuration to provide an installer.
Re: Making Eclipse with special configuration [message #1720296 is a reply to message #1720294] Sat, 16 January 2016 03:57 Go to previous messageGo to next message
Thanks, perfect! I will try it today.
[Updated on: Sat, 16 January 2016 03:57] by Moderator
Re: Making Eclipse with special configuration [message #1720325 is a reply to message #1720294] Sun, 17 January 2016 04:49 Go to previous messageGo to next message
I tried to work with oomph or better to say start to working with oomph but I couldn't do what I wanted. What I want to do it's not to complicated. I want to install a Kalper eclipse with special version of xtext and xcore tools which are installed in my eclipse.
I still don't find a solution ! Confused
Re: Making Eclipse with special configuration [message #1720326 is a reply to message #1720325] Sun, 17 January 2016 04:53 Go to previous messageGo to next message
ask at the oomph forum for help but I don't think oomph works with
kepler but only mars. Kepler is really old already!
Tom
> I still don't find a solution ! :?
Re: Making Eclipse with special configuration [message #1720327 is a reply to message #1720326] Sun, 17 January 2016 05:19 Go to previous messageGo to next message
This solution doesn't give you a preconfigured eclipse instance, requires an additional step (import).
In your eclipse: File -> Export -> Installed Software Items to File -> Select your plugins
In the other eclipse: File -> import -> Installed Software Items from File -> Select your previosly exported file
Re: Making Eclipse with special configuration [message #1720337 is a reply to message #1720327] Sun, 17 January 2016 13:29 Go to previous message
I was a very interesting tool. I didn't know about it but unfortunately it didn't work. I have exported the plug-ins but when I imported it in another eclipse the installation was not successful.
Maybe because one of the plug-ins was installed in current eclipse with zip file therefor it couldn't be installed in new eclipse. Actually none of the plug-ins were installed.
[Updated on: Sun, 17 January 2016 13:29] by Moderator
Previous Topic:SWT table widget and multi column sorting
Next Topic:solution to "WorkbenchWindowAdvisor.createWindowContents(Shell))" not working in eclipse 4
Current Time: Sun Jul 20 18:27:50 EDT 2025
Powered by FUDForum. Page generated in 0.03875 seconds
