Home » Modeling » TMF (Xtext) » Cross reference issue while using EmbeddedEditor
Cross reference issue while using EmbeddedEditor [message #1720239] Fri, 15 January 2016 08:52 Go to next message
Code used to show xtext control (embedded mode) in a standalone application
               EmbeddedEditorFactory factory = injector.getInstance(EmbeddedEditorFactory.class);
		handle = factory.newEditor(resourceProvider).showErrorAndWarningAnnotations().withParent(parent);
		LineNumberRulerColumn lnrc = new LineNumberRulerColumn();
		handle.getViewer().addVerticalRulerColumn(lnrc);
To add cross reference capability in standalone application, i injected "ResourceSetBasedAllContainersState" class for IAllContainersState interface in "NGXUiModule"
		var state = new ResourceSetBasedAllContainersState();
		var containers = Arrays.asList("All");
		var container2Uris = ArrayListMultimap.create();
		container2Uris.put("Base", URI.createFileURI("/Users/XYZ/file1.ngx"));
		container2Uris.put("Base", URI.createFileURI("/Users/XYZ/file2.ngx"));
		state.configure(containers, container2Uris)
		return state;
"ngx" is the extension provided while creating the xtext project
When i open file2.ngx file using xtext editor in standalone application, it is not looking in file2.ngx for its references.
It gives "Couldn't resolve reference to " error.
Please help me to solve this cross reference issue.
Saravanan A
Re: Cross reference issue while using EmbeddedEditor [message #1720256 is a reply to message #1720239] Fri, 15 January 2016 10:11 Go to previous messageGo to next message
You should populate the resource set in the resourceprovider
Re: Cross reference issue while using EmbeddedEditor [message #1720261 is a reply to message #1720256] Fri, 15 January 2016 10:34 Go to previous messageGo to next message
Re: Cross reference issue while using EmbeddedEditor [message #1720276 is a reply to message #1720261] Fri, 15 January 2016 13:12 Go to previous messageGo to next message
I have tried that too...Still not working...
public class NGXResourceProvider implements IEditedResourceProvider {
	@Inject
	private IResourceSetProvider resourceSetProvider;
	private XtextResource resource;
	public XtextResource createResource() {
		try {
			if (resource != null) {
				return resource;
			ResourceSet resourceSet = resourceSetProvider.get(null);
			Resource baseResource = resourceSet.createResource(URI.createFileURI("/Users/XYZ/file1.ngx"));
			resourceSet.createResource(URI.createFileURI("/Users/XYZ/file2.ngx"));
			resource = (XtextResource) baseResource;
			return resource;
		} catch (Exception e) {
			return null;
	public XtextResource getResource() {
		return resource;
		NGXResourceProvider resourceProvider = injector.getInstance(NGXResourceProvider.class);
		this.resource = resourceProvider.createResource();
Re: Cross reference issue while using EmbeddedEditor [message #1720279 is a reply to message #1720276] Fri, 15 January 2016 15:20 Go to previous messageGo to next message
can you share a complete minimal reproduceable example? how does you guice setup look like?
i am not sure that xtext will work truely standlone so having a starting point to analyse would help.
Re: Cross reference issue while using EmbeddedEditor [message #1720295 is a reply to message #1720279] Sat, 16 January 2016 03:01 Go to previous messageGo to next message
Please create below mentioned to 2 files in any directory and change
DirectoryUtil.java (org.xtext.example.ngx.ui/src/org/xtext/example/ngx/ui/) accordingly.
file1.ngx content
Type Name as STRING
file2.ngx content
Entity entity1 as Name
In NgxUiModule, i have injected the "ResourceSetBasedAllContainersState" provider.
Check View.java (StandalonePrj) for Embedded XText editor creation.
Re: Cross reference issue while using EmbeddedEditor [message #1720297 is a reply to message #1720279] Sat, 16 January 2016 04:50 Go to previous messageGo to next message
i dont see anything on "standalone" in your project. it is all eclipse based. standalone in terms of xtext is "without osgi AND workspace environment".
so if you want to use a resourcesetbased index in eclipse you have to configure that
class NgxUiModule extends AbstractNgxUiModule {
	def configureIResourceDescriptions(Binder binder) {
		binder.bind(IResourceDescriptions).to(ResourceSetBasedResourceDescriptions).in(Scopes.SINGLETON);
	override Class<? extends IAllContainersState.Provider> bindIAllContainersState$Provider() {
		return ResourceSetBasedAllContainersStateProvider;
public class CustomCLangResourceProvider implements IEditedResourceProvider {
	@Inject
	private Provider<ResourceSet> resourceSetProvider;
		try {
				return resource;
			ResourceSet resourceSet = resourceSetProvider.get();
			for (URI uri : DirectoryUtil.getAllUris()) {
				Resource baseResource = resourceSet.createResource(uri);
			return resource;
			return null;
		return resource;
Re: Cross reference issue while using EmbeddedEditor [message #1720301 is a reply to message #1720297] Sat, 16 January 2016 08:40 Go to previous messageGo to next message
StandalonePrj is a RCP application and not used as plugin inside eclipse. I don't see a workspace environment here. Correct me if i am wrong.
Where should i place these 2 files(ngx files), so that xtext can resolve cross reference dependencies ?
Thanxs for quick reply.
Saravanan A
Re: Cross reference issue while using EmbeddedEditor [message #1720302 is a reply to message #1720301] Sat, 16 January 2016 08:51 Go to previous messageGo to next message
they re are actually your files patched. then it works (on my machine)
what is the error you get?
[Updated on: Sat, 16 January 2016 09:00] by Moderator
Re: Cross reference issue while using EmbeddedEditor [message #1720309 is a reply to message #1720302] Sat, 16 January 2016 10:11 Go to previous messageGo to next message
Thanx you so much. It works...
Is there any provider which scans the directory (monitor the changes) and loads all the ngx files ?
Re: Cross reference issue while using EmbeddedEditor [message #1720310 is a reply to message #1720309] Sat, 16 January 2016 10:20 Go to previous messageGo to next message
No (maybe you can make
Use of xtext.mwe.reader
Re: Cross reference issue while using EmbeddedEditor [message #1720312 is a reply to message #1720310] Sat, 16 January 2016 10:30 Go to previous message
If you know any sample/tutorial about reader please give some pointers...
Previous Topic:Problems getting xtext running in IntelliJ
Next Topic:How to add formatter based on the new formatting API to the project
Current Time: Sat Jul 19 23:52:33 EDT 2025
Powered by FUDForum. Page generated in 0.10158 seconds
