Home » Eclipse Projects » Requirements Modeling Framework  » Enumeration data type
Enumeration data type [message #1720008] Wed, 13 January 2016 12:15 Go to next message
Can the enumeration data type be used with a spec type, in order to provide a list of items, from which one can be selected?
Using the example of a priority field:
Must
Should
Could
Won't
Re: Enumeration data type [message #1720120 is a reply to message #1720008] Thu, 14 January 2016 09:52 Go to previous messageGo to next message
Hello Max,
Yes, this is possible. You need to create an Enumeration DatatypeDefinition and assign it to the AttributeDefinition of the SpecType
Also described in the Handbook: http://formalmind.com/handbook?page=sec-datatype_configuration.html
Best,
- Michael
Re: Enumeration data type [message #1720704 is a reply to message #1720120] Wed, 20 January 2016 06:20 Go to previous messageGo to next message
Yes, thanks - worked it out from those instructions. Question - is there any kind of multi-select enumerable available? I wish to have a field that allows me to select multiple entries for a requirement (specifically if a requirement can be traced back to more than one customer)
Re: Enumeration data type [message #1720743 is a reply to message #1720704] Wed, 20 January 2016 10:43 Go to previous message
Hello Max,
Yes, in the AttributeDefinition: select the Attribute in the SpecType and you find the property "Multi Valued". This is kind of unintuitive, but that's how ReqIF is structured.
Best,
- Michael
Previous Topic:Image support?
Next Topic:JavaFX issues with the XHTML editor
Current Time: Sat Jul 19 05:45:23 EDT 2025
Powered by FUDForum. Page generated in 0.03747 seconds
