Formatter does not support Ratliff style [message #1719835] |
Tue, 12 January 2016 09:04  |
Our developers currently use jIndent in both Eclipse and Netbeans, and years and years of discussions and compromises lead us to use Ratliff- or banner-style ( en.wikipedia.org/wiki/Indent_style#Ratliff_style ) for brace placements in all languages used: C, perl, java, ruby
The managers want to save money and abolish jIndent and use the default formatters in the IDE and asked me to find where they fall short.
So far I have not spotted an option in NetbeansEclipse' java formatter to select indentation of the closing brace.
Did I miss it? Is there an option to get the NetbeansEclipse java formatter to do what we want?
if (c.isFoo ()) {
if (c.isBar ())
return;
String str = c.getActionDescription ();
if ("ABORT".equals (str)) {
process.abort ();
LOG.info ("Process aborted");
else
LOG.info ("Process will do " + str);
Please don't answer if all you do is vent the opinion that you think that is a stupid style. You are entitled to have your own opinion and I agree that you may disagree with the required layout/style: end of argue. Note that it is not up to you to set developer-group rules. I'm just seeking the option to use this style, and jIndent is supporting that.
[Updated on: Wed, 13 January 2016 08:23] by Moderator
Re: Formatter does not support Ratliff style [message #1719860 is a reply to message #1719840] |
Tue, 12 January 2016 11:19  |
There's still a copy-paste error, but I can see past it.
The short answer is: I don't see an option to adjust the placement of closing braces.
Perhaps your management would consider allowing you to contribute such an option, since by doing so they can stop paying for jIndent (assuming there is some other solution for NetBeans).
FUDForum. Page generated in 0.04049 seconds
