Home » Modeling » GMF (Graphical Modeling Framework) » create node using outgoing connection handle(Unable to create nodes using outgoing connection handles)
create node using outgoing connection handle [message #1719161] Tue, 05 January 2016 12:19 Go to next message
After installing windows 10, I am unable to create a node from an outgoing connection handle in the GMF editor. Applies to creating notes too. I am using kepler. This works perfectly in Windows 8.1 and 8. It is frustrating and I have failed to find a solution for this bizarre issue. Has anyone encountered such an issue? I don't know if this is related to GMF, eclipse or Windows 10. Any help would be appreciated.
Thanks in advance
Re: create node using outgoing connection handle [message #1756015 is a reply to message #1719161] Fri, 10 March 2017 02:02 Go to previous message
I am also facing same issue. if you got your answer can you post how you solved it
Previous Topic:Link style doesnt work
Next Topic:Create Node without EClass?
Current Time: Sun Jul 20 17:52:28 EDT 2025
Powered by FUDForum. Page generated in 0.02790 seconds
