Home » Archived » EPF » 64-bit Linux(EPF seems to use 32-bit)
64-bit Linux [message #892652] Thu, 28 June 2012 21:58 Go to next message
I am currently running 64-bit ubuntu and 64-bit Oracle Java 7. The current version of EPF (1.5.4?) seems to require 32-bit.
I am hoping that there will be a version that will allow for use in my environment. Many Linux users have migrated to 64-bit environments and frankly, I would prefer to stay there.
Another alternative might be to install EPF as plugins into my existing Eclipse environment (Indigo 64-bit Linux), but I'm not sure that's possible.
Any suggestions would be much appreciated - I would like to get to know this program, since it looks like it will fill a need.
Many thanks,
Re: 64-bit Linux [message #927430 is a reply to message #892652] Sat, 29 September 2012 12:58 Go to previous messageGo to next message
I have the same issue! I am wondering if I need to remove the 64 bit Java?
Re: 64-bit Linux [message #997349 is a reply to message #927430] Sun, 06 January 2013 13:49 Go to previous messageGo to next message
Same here. I looked into building my own, but, frankly, it seemed like a lot of work with an uncertain outcome (in particular the dependencies to the native html rendering engine make me worry that I get the thing to compile, but the editors being unusable).
Is the EPF build even automated? I have not seen it at https://hudson.eclipse.org/hudson/
*Bump* [message #1068185 is a reply to message #997349] Fri, 12 July 2013 10:48 Go to previous messageGo to next message
Just wondering - as time passes, and almost all machines have >3GB, I see fewer and fewer 32bit Linux machines. A 64bit built would be greatly appreciated.
Re: *Bump* [message #1068582 is a reply to message #1068185] Sat, 13 July 2013 15:39 Go to previous messageGo to next message
I couldn't agree with Michael more - a 64-bit version for Linux is very important going forward.
Re: *Bump* [message #1068583 is a reply to message #1068185] Sat, 13 July 2013 15:40 Go to previous messageGo to next message
Re: *Bump* [message #1402991 is a reply to message #1068583] Sat, 19 July 2014 10:01 Go to previous messageGo to next message
So we're now another year down the road and Linux continues to move on. Firefox has 64-bit version for Linux - but not for Windows. Ubuntu is now at 14.04. As far as I know, LibreOffice is 64-bit. I think there is a recently released version of RedHat Linux that is 64-bit. We are still waiting for someone to let us know when we will be able to run EPF on 64-bit Linux. I won't install 32-bit Linux just to run EPF. Even Windows applications are slowly migrating to 64-bit. So when do we think there will be a 64-bit version of EPF?
Re: *Bump* [message #1657270 is a reply to message #1402991] Sat, 07 March 2015 17:35 Go to previous messageGo to next message
We are now an ADDITIONAL 4 -1/2 years down the road. Is there any prospect that there will be a 64-bit version of EPF to run on 64-bit Java?
Re: *Bump* [message #1693276 is a reply to message #1657270] Wed, 22 April 2015 15:50 Go to previous messageGo to next message
Unless someone steps up to do this, it won't happen any time soon. However, I have gotten Rational Method Composer working on 64 bit SUSE, so I assume EPF Composer will also work on the same platform. I then tried various workarounds to get it working on Ubuntu 64 - but was not successful. I imagine that someone with more technical know-how than I could compare the SUSE and Ubuntu environments and figure out how to get this working on Ubuntu 64.
Volunteers anyone?
Re: 64-bit Linux: Got it to work with CrossOver [message #1719096 is a reply to message #892652] Tue, 05 January 2016 03:43 Go to previous messageGo to next message
Hi all,
I got it to work by running the Windows version with CrossOver (commercial counterpart of wine). To me, this is better than anything else I found so far. Here are the installation instructions:
http://jastram.de/blog/blog.php?/archives/414-Eclipse-Process-Framework-EPF-on-Linux-64-bit.html
For those not willing to spent €50 for CrossOver, maybe someone will explore using wine instead.
- Michael
Visit my Blogs: http://se-trends.de | http://formalmind.com/blog | http://jastram.de/blog
Re: 64-bit Linux [message #1728851 is a reply to message #892652] Thu, 07 April 2016 17:25 Go to previous messageGo to next message
The solution that worked for me was:
1. get a 32 bits java VM (download form otn.oracle.com)
2. adjust epf-composer/epf.ini to use it. Adding the following two lines starting epf.ini
-vm
/usr/lib/jvm/java-1.7.0-oracle-1.7.0.79/jre/bin/java
Hope it helps
Re: 64-bit Linux [message #1728866 is a reply to message #1728851] Fri, 08 April 2016 02:39 Go to previous messageGo to next message
Hi Javier,
Thanks for the hint. But did you try to edit rich text (HTML)? I suspect that EPF will crash if you attempt this.
Best,
- Michael
Re: 64-bit Linux [message #1792811 is a reply to message #1728851] Tue, 24 July 2018 06:11 Go to previous messageGo to next message
Javier Alcala wrote on Thu, 07 April 2016 21:25
How did you solved the rich test editing? Using a recent xulrunner? downloading an ancient Firefox version?
Re: 64-bit Linux [message #1797639 is a reply to message #892652] Sat, 03 November 2018 06:17 Go to previous message
Just for the record:
Now I can run EPF Composer natively in 64 bits Linux. Check this post for details: http://olea.org/diario/2018/11/02/EPF_Composer_in_Linux.html
Previous Topic:EPF Wiki
Next Topic:EPF and ontology
Current Time: Sun Jul 20 07:42:39 EDT 2025
Powered by FUDForum. Page generated in 0.05547 seconds
