Home » Eclipse Projects » Oomph » Linked resources are not supported by this application.
Linked resources are not supported by this application. [message #1718204] Mon, 21 December 2015 04:59 Go to next message
I recently started to get this error when performing the import projects
setup tasks
"Linked resources are not supported by this application."
I had never seen this before... anyone else experienced this?
thanks in advance
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Linked resources are not supported by this application. [message #1718238 is a reply to message #1718204] Mon, 21 December 2015 09:01 Go to previous messageGo to next message
Lorenzo,
Is Window -> Preferences -> General -> Workspace -> Linked Resources ->
Enable linked resources enabled/checked in this case?
On 21/12/2015 10:59 AM, Lorenzo Bettini wrote:
> Hi
> setup tasks
> thanks in advance
> Lorenzo
Re: Linked resources are not supported by this application. [message #1718239 is a reply to message #1718204] Mon, 21 December 2015 09:01 Go to previous messageGo to next message
Lorenzo,
> Hi
> setup tasks
> thanks in advance
> Lorenzo
Re: Linked resources are not supported by this application. [message #1718319 is a reply to message #1718238] Tue, 22 December 2015 06:47 Go to previous messageGo to next message
On 21/12/2015 15:01, Ed Merks wrote:
> Lorenzo,
Hi Ed
Actually, it wasn't enabled, and I don't know why :)
I've always used linked resources myself in other workspaces. In this
specific project there were no linked resources anyway...
In any case, I forced this option in the Oomph setup and now everything
works file:
http://git.eclipse.org/c/emf-parsley/org.eclipse.emf-parsley.git/commit/?id=d34f741a32de15c80ce900d5712ee27faeca58ec
thanks
Lorenzo
Xtext Book:
Re: Linked resources are not supported by this application. [message #1744659 is a reply to message #1718319] Thu, 29 September 2016 06:42 Go to previous messageGo to next message
I have gotten this at today. Maybe has something to do with neon.1 which was released?
Re: Linked resources are not supported by this application. [message #1744672 is a reply to message #1744659] Thu, 29 September 2016 08:16 Go to previous messageGo to next message
I tested a fresh install and here the option is enabled. I wonder how it became inactive in the other installation.. :/
Re: Linked resources are not supported by this application. [message #1745191 is a reply to message #1744672] Thu, 06 October 2016 04:33 Go to previous messageGo to next message
I get this now every single time I run the setup tasks. Do you think I could install a simple tracer that dumps a stack when this preference changes, so I could find out what is causing it?
Re: Linked resources are not supported by this application. [message #1745198 is a reply to message #1745191] Thu, 06 October 2016 07:40 Go to previous messageGo to next message
If you want this always to be true, why not just record it into your user setup or your project setup?
Re: Linked resources are not supported by this application. [message #1745203 is a reply to message #1745198] Thu, 06 October 2016 08:49 Go to previous messageGo to next message
No, I don't quite accept that 'something' updates a preference in a sneaky way like it's currently happening. I will try to fix this the hard way. Having oomph re-set it to my liking would only cure the symptom.
Re: Linked resources are not supported by this application. [message #1745410 is a reply to message #1745203] Mon, 10 October 2016 08:36 Go to previous messageGo to next message
Me too.
The error message out of the blue looks bogus to me.
Does importing git projects via Oomph require this capability?
Is importing a project already creating a linked resource? (Doc speaks only of linked resources *within* a project - which should not be needed in my case).
... confused ...
Edit: In my case this happened in Mars.2, only Oomph and Egit have been updated to their 201609 versions. Maybe this helps to narrow down the culprit.
[Updated on: Mon, 10 October 2016 08:39] by Moderator
Re: Linked resources are not supported by this application. [message #1745420 is a reply to message #1745410] Mon, 10 October 2016 10:25 Go to previous message
Nothing in Oomph is specifically creating linked resources but if the projects being imported contain linked resources then I suppose that importing them would require the workspace to allow that. I don't know what would disable that preference; it always is true for me and I haven't recorded it that way.
Previous Topic:Update an already eclipse installed through oomph
Next Topic:Error installing .setup
Current Time: Sun Jul 20 02:25:22 EDT 2025
Powered by FUDForum. Page generated in 0.05921 seconds
