Re: QVTo Trace Editor doesn't show properties of elements [message #1717638 is a reply to message #1717610] |
Tue, 15 December 2015 08:45  |
Correction: You can Open with the Sample Reflective Ecore Editor to get
the really standard EMF editor, with a Properties View.
The Operation QVT Trace Editor is a customized view in which all the
properties are represented in the visible text.
However neither editor allows you to trace from the EObject reference to
the EObject, which is where you could find more information.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=484391 raised
Ed Willink
On 15/12/2015 09:47, Denis Nikiforov wrote:
> In Properties View I can see only properties of qvtotrace-file (path,
> size, last modified, ...).
> I've got it! I saw element properties in debug mode:
> There is a real classes (Model, Package, ...) Instead of EObjects and
> real properties.
> Is it impossible to see the same detailed information not only in
> debug mode but also in simple QVT Trace Editor?
FUDForum. Page generated in 0.04992 seconds
