Home » Newcomers » Newcomers » Mac: Java CocoaComponent compatibility mode
Mac: Java CocoaComponent compatibility mode [message #171686] Wed, 20 September 2006 02:27 Go to next message
Originally posted by: wakon.sbcglobal.net
as a newbie I got lost receiving the following message after launching
some java code from within Eclipse having some swing components: [Java
CocoaComponent compatibility mode]: Enabled, [Java CocoaComponent
compatibility mode]: Setting timeout for SWT to 0.100000. Then the app is
frozen. It worked previously until I experimented a little with
JFreeReport/Panthone BI/reporting.
I am on:
Eclipse Version: 3.1.0, Build id: I20050627-1435
Mac OS X 10.4.7
java version "1.4.2_09"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_09-232)
Java HotSpot(TM) Client VM (build 1.4.2-54, mixed mode)
I have seen one bug report related to this topic but what is written there
is more or less greek to me and a) it says its fixed and b) it seems by
running this JFreeReport stuff some setting or so was changed so that now
I have this issue (it worked before).
Anyone any idea? I am stuck and want to continue writing some software for
a school ...
Many thanks for any help!
Wolfgang
Re: Mac: Java CocoaComponent compatibility mode [message #171710 is a reply to message #171686] Wed, 20 September 2006 03:23 Go to previous messageGo to next message
On Java 1.4+ the SWT-AWT bridhge is broken, so no swing integration is possible.
Wolfgang schreef:
> Hello,
> is frozen. It worked previously until I experimented a little with
> I am on:
> Mac OS X 10.4.7
get java 1.5 from connect.apple.com or developer.apple.com
> there is more or less greek to me and a) it says its fixed and b) it
> seems by running this JFreeReport stuff some setting or so was changed
> so that now I have this issue (it worked before).
> for a school ...
> Wolfgang
Re: Mac: Java CocoaComponent compatibility mode [message #171778 is a reply to message #171710] Wed, 20 September 2006 10:20 Go to previous messageGo to next message
Originally posted by: jefmyers.us.ibm.com
Wolfgang,
You'll also have to be using Eclipse 3.2 if you want to use the SWT_AWT
bridge on OS X. See http://www.eclipse.org/swt/faq.php#swtawtosx for
details.
Hope this helps,
- Jeff
> possible.
> Wolfgang schreef:
>> Hello,
>> I am on:
>> Mac OS X 10.4.7
>> for a school ...
>> Wolfgang
Re: Mac: Java CocoaComponent compatibility mode [message #171944 is a reply to message #171778] Thu, 21 September 2006 01:01 Go to previous messageGo to next message
Jeff, Marteen,
thank you very much for your reply. I have now:
- Eclipse Version: 3.2.0, Build id: M20060629-1905.
- java version "1.5.0_06"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_06-112)
Java HotSpot(TM) Client VM (build 1.5.0_06-64, mixed mode, sharing)
- Installed 'eclipse-SDK-3.2-macosx-carbon' from the apple developer site.
It worked fine - ONE time. Then, before backing up my laptop, I wanted to
make sure everything comes up fine and just started one after another:
Apple Pages, Adobe Illlustrator 12, Maya 7, iCal, AddressBook, iTunes and
TextWrangler. After exiting those apps I launched my Java app again and
... darn ... the same message and a frozen app as before.
I guess there must be some parameter/switch some app overwrites or alike.
Do you have any idea?
Thanks a mill'.
Wolfgang
Re: Mac: Java CocoaComponent compatibility mode [message #171952 is a reply to message #171944] Thu, 21 September 2006 01:05 Go to previous message
Sorry, I meant I installed: * j2se50release4swtcompatibility * from
apple's dev site !
Previous Topic:Eclipse 3.2 Code Assist Computing Additional Info
Next Topic:how to configure BIRT with RAD 6.0
Current Time: Sat Jul 19 12:03:59 EDT 2025
Powered by FUDForum. Page generated in 0.08938 seconds
