Home » Eclipse Projects » Gendoc » Installation cannot be completed.
Installation cannot be completed. [message #1715849] Thu, 26 November 2015 10:33 Go to next message
I would like to use Gendoc with Capella but the installation cannot be completed.
You'll find a screenshot of the details I got from Capella enclosed to this post.
I don't know where to find the "missing requirement" I need to complete the installation.
Can someone help me on this subject?
Gregoire
Re: Installation cannot be completed. [message #1716084 is a reply to message #1715849] Tue, 01 December 2015 02:54 Go to previous messageGo to next message
Hello did you take a loot at this post on the Capella forum : https://polarsys.org/forums/index.php/t/126/
normally the procedure should work to use capella with Gendoc
Re: Installation cannot be completed. [message #1716524 is a reply to message #1716084] Fri, 04 December 2015 09:21 Go to previous messageGo to next message
Hello Tristan,
Yes I did look at this post, it describes what to do if an error occures during the installation:
During this installation, this error may appear:
Cannot complete the install because one or more required items could not be found.
Software being installed: Sirius - Capella bundle for Gendoc 0.5.0.201506041603 (org.eclipse.gendoc.sirius.feature.feature.group 0.5.0.201506041603)
Missing requirement: Sirius - Capella bundle for Gendoc 0.5.0.201506041603 (org.eclipse.gendoc.sirius.feature.feature.group 0.5.0.201506041603) requires 'org.eclipse.emf.feature.group 2.10.0' but it could not be found
If this case, you should install the latest version of EMF, as indicated on Gendoc forum: «https://www.eclipse.org/forums/index.php?t=msg&th=1066 005&goto=1693793&#msg_1693793 »
After these, restart your Eclipse platform.
But the link might be dead, and the error that appear when I try to install Gendoc is not the same:
[Updated on: Fri, 04 December 2015 09:22] by Moderator
Re: Installation cannot be completed. [message #1716672 is a reply to message #1716524] Mon, 07 December 2015 07:55 Go to previous message
Ok it seems there are problems with capella plugins.
We will investigate it, can you try the procedure installing the 0.5.0 version of Gendoc : http://www.eclipse.org/downloads/download.php?file=/gendoc/releases/0.5/org.eclipse.gendoc.incubation.update-site-0.5.0.zip
Previous Topic:Question on sortedBy
Next Topic:How to access ibd ?
Current Time: Sun Jul 20 18:42:35 EDT 2025
Powered by FUDForum. Page generated in 0.04423 seconds
