Home » Eclipse Projects » Oomph » Manipulating Oomph setup models programatically
Manipulating Oomph setup models programatically [message #1716134] Tue, 01 December 2015 10:52 Go to next message
I'd like to manipulate Oomph setup models programmatically and it being an EMF model I'd like to use EMF of course.
I'm able to read a model and traverse it but I'm not able to change property values e.g the VersionRange of a P2Director Requirement element since there is no setters.
Any suggestions?
Patrik
Re: Manipulating Oomph setup models programatically [message #1716138 is a reply to message #1716134] Tue, 01 December 2015 10:59 Go to previous messageGo to next message
Patrick,
There's org.eclipse.oomph.p2.Requirement.setVersionRange(VersionRange).
On 01/12/2015 4:52 PM, Patrik Nandorf wrote:
> Any suggestions?
> Regards
> Patrik
Re: Manipulating Oomph setup models programatically [message #1716147 is a reply to message #1716138] Tue, 01 December 2015 11:56 Go to previous messageGo to next message
Thanks Ed,
Ok, there is obvioulsy a setVersionRange(), sorry missed that.
Also I wasn't clear on what I'm trying to do which is to change the max version of the range of a requirement.
My assumed approach to this was to get the range, get the max version, increment it and set the new value to the range.
This I can't do since I can't set the Versions in a VersionRange object due to lack of setters.
Then I tried to create a new VersionRange to set. However createVersionRange takes a Version and VersionSegment which I haven't figured out how to use to set specific min and max versions.
Hope this explains my problem better.
Patrik
Re: Manipulating Oomph setup models programatically [message #1716149 is a reply to message #1716147] Tue, 01 December 2015 12:12 Go to previous messageGo to next message
Hi Patrik,
P2Factory.createVersionRange(Version, VersionSegment) is a convenience factory method to create version ranges that
include a given version and versions up to the next specified version segment. For example, if you have an installable
unit iu with the version 1.0.0 the call P2Factory.eINSTANCE.createVersionRange(iu.getVersion(), VersionSegment.MICRO)
returns the version range [1.0.0,1.0.1), i.e. all version qualifiers in that range.
Note that VersionRange is really a p2 class. You can create instances directly by calling one of the constructors.
Cheers
/Eike
http://www.esc-net.de
Am 01.12.2015 um 17:56 schrieb Patrik Nandorf:
> Thanks Ed,
> Regards
> Patrik
Re: Manipulating Oomph setup models programatically [message #1716215 is a reply to message #1716149] Wed, 02 December 2015 04:25 Go to previous message
Thanks Eike, works like a charm.
Previous Topic:Search Dialog Setting "Search page selection" for my User Scope
Next Topic:Bundle Pool Management Dialog - greyed out elements
Current Time: Sun Jul 20 03:38:04 EDT 2025
Powered by FUDForum. Page generated in 0.51724 seconds
