Home » Eclipse Projects » Sirius » How to find if a diagram is already created for an element ?
How to find if a diagram is already created for an element ? [message #1716179] Tue, 01 December 2015 19:41 Go to next message
I have a Feature F, I need to create an State Machine Diagram (Canvas) for F. I can do it now. I can also open the corresponding diagram by double clicking on the feature F. But here is the question:
When I want to create the diagram for feature F, I need to check that a diagram has already been created for the feature F or not! If, it has already been created, don't create it again! How to do this ?
Parsa
Re: How to find if a diagram is already created for an element ? [message #1716534 is a reply to message #1716179] Fri, 04 December 2015 11:01 Go to previous messageGo to next message
Hi Parsa,
You can use the API
DialectManager.INSTANCE.getRepresentations(semanticElement,
currentSiriusSession) to find every representation created on
"semanticElement" and then investigate if a State Machine Diagram exists
among them.
Steve
Le 02/12/2015 01:41, Parsa Pourali a écrit :
> Regards,
> Parsa
Steve Monnier - Obeo
Need professional services for Sirius?
Re: How to find if a diagram is already created for an element ? [message #1716538 is a reply to message #1716534] Fri, 04 December 2015 11:24 Go to previous messageGo to next message
I replied a bit too fast and overlooked that you want it for a double
click tool. In your tool, you can add a precondition expression without
using a java service. The expression would look like this:
aql:not(self.eInverse()->filter(diagram::DDiagram).description.name->includes('yourDiagramID'))
where yourDiagramID is the name you sent in the VSM for your State
Machine Diagram.
Steve
Le 04/12/2015 17:01, Steve Monnier a écrit :
> Hi Parsa,
> You can use the API
> among them.
> Regards,
> Steve
>> Hi,
>> Thanks,
>> Regards,
>> Parsa
Re: How to find if a diagram is already created for an element ? [message #1716544 is a reply to message #1716538] Fri, 04 December 2015 11:56 Go to previous messageGo to next message
Hi Steve,
Thanks a lot for your help. I used the expr you posted and it worked great ! Thank you, it was exciting Very Happy
I have two Questions now:
1- If I'm gonna use DialectManager (someday), should I write a Java Service and use it in that service?
2- What should I refer to as a session ? With Java service I have access to the EObject that triggering the java service, should I just use SessionManager.INSTANCE.getSession(theSemanticElement to get the active session ?
Bests,
Parsa
[Updated on: Fri, 04 December 2015 12:05] by Moderator
Re: How to find if a diagram is already created for an element ? [message #1716679 is a reply to message #1716544] Mon, 07 December 2015 08:30 Go to previous message
Le 04/12/2015 17:56, Parsa Pourali a écrit :
> Hi Steve,
> Thanks a lot for your help. I have three Questions now:
Not necessarily. DialectManager can be used to drive Sirius from code
which is not invoked from inside a VSM. For example from a normal
Eclipse action/handler, or a wizard, etc.
> session ?
Yes, if you have a semantic/busniess model element which comes from a
Sirius session that is the recommended API to obtain the corresponding
session.
> 3- I'm using the aql expr you kindly posted, I could manage to use
> eInverse() and it return several elements. However, when I use eInverse
> (diagram::DDiagram), it returns null. And I am sure that there is a
> representation for it. so it shuld not be empty. So, I used eInverse
> (diagram::DDiagramElement) and it returned two elements which I can see
> are diagram elements. The problem with using DDiagramElement is that
> there is no description attribute for it :( Do you have any idea why
> diagram::DDiagram returns empty ?
No, from the look of the expression Steve provided, I would say it
should work. Provided there is really a diagram "rooted" on that element
(not just where the element appears on the diagram) inside the same
Sirius session.
Pierre-Charles
Pierre-Charles David - Obeo
Previous Topic:How to create Border Node with a Domain Class not in the semantic model
Next Topic:Can't create a Node with Border Nodes
Current Time: Sun Jul 20 17:44:13 EDT 2025
Powered by FUDForum. Page generated in 0.03797 seconds
