| Parts from a perspective that is not active are not closed [message #1716092] |
Tue, 01 December 2015 04:30  |
I have an e4 application that has two perspective:
1) Operations
2) Configuration -> Contains (among other things) a part stack where the configurations are opened.( Each configuration in a part)
When a new model is loaded all configuration parts are to be closed. This works fine if I load the new model when the configuration perspective is active.
However, if I open some configurations in the Configuration Perspective. Switch to the Operations perspective and load a new model. I can see in the logs that the code to close the parts is called and everything seems to be alright. However, when i switch back to the configuration perspective the parts are still visible an open.
Could somebody tell me how to make sure that the parts are close, regardless of the active perspective?
FUDForum. Page generated in 0.04803 seconds
