Home » Modeling » Papyrus » Activity Diagram bugs/questions
Activity Diagram bugs/questions [message #1715252] |
Fri, 20 November 2015 10:03  |
Validation of my model reported an error with an Object Flow on an Activity diagram. When I selected the object flow and look at the SysML properties, I noticed that the properties are all duplicated.
That is the bug. Now the questions.
The validation error is "The required feature 'sysml:activities:Rate:rate' of Continuous must be set. I have a stereotype of <<Continuous>> so that should set the rate, no? When I select the ellipsis button next to the Rate property it brings up an empty dialog window and there does not seem to be a way to add anything.
The next question is straight forward. How do I get the icon for a CallBehaviorAction as shown in para 11.3.1.2 of the SysML 1.4 spec. to display? I can't find any property or display filter to do it.
Last question is: How can I hide the name of the InitialNode or ActivityFinalNode without deleting the name? This question also applies to StateMachine diagrams.
This with SysML 1.4 v0.7.0.201509161524.
Steve
Re: Activity Diagram bugs/questions [message #1715440 is a reply to message #1715252] |
Mon, 23 November 2015 10:13   |
Hi Stephen,
First: If you're trying/insisting to use the (in-progress) SysML 1.4 editors, I suggest to use the nightly build update site. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=472801
Stephen Blackwell wrote on Fri, 20 November 2015 10:03Validation of my model reported an error with an Object Flow on an Activity diagram. When I selected the object flow and look at the SysML properties, I noticed that the properties are all duplicated.
That is the bug.
I can confirm this. More specifically: this only happens when a SysML specific stereotype is set. Could you file a bug report for this?
Now the questions.
This is an interesting one. For Rate, the spec says
From Spec
When the «rate» stereotype is applied to an activity edge, it specifies the expected value of the number of objects and values that traverse the edge per time interval, that is, the expected value rate at which they leave the source node and arrive at the target node. ...
The «rate» stereotype has a rate property of type InstanceSpecification. The values of this property must be instances of classifiers stereotyped by «valueType» or «distributionDefinition», see Clause 8, "Blocks." In particular, the denominator for units used in the rate property must be time units.
From Spec
Continuous rate is a special case of rate of flow (see Rate) where the increment of time between items approaches zero.
However, AFAICT the spec does not mention to what value the rate attribute needs to be set in this case. IMO this is a problem with the SysML specification (which I cannot find back directly in the OMG issue list). So my guess is that this should be reported to the OMG SysML issue tracker www.omg.org/report_issue.htm
I cannot find back this in para 11.3.1.2 of the SysML 1.4 spec?
ActivityDiagram InitialNode > Label
visible : false;
(Disclaimer: it's not that I'm just smart, I just got this answer from peaking in the css files that come with papyrus code)
HTH,
Klaas
Steve
Re: Activity Diagram bugs/questions [message #1716153 is a reply to message #1715440] |
Tue, 01 December 2015 13:15   |
Quote:First: If you're trying/insisting Smile to use the (in-progress) SysML 1.4 editors, I suggest to use the nightly build update site. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=472801
I do insist
OK, done, but I got some dialog about migrating profiles. I chose the SysML option. I hope that's right.
That is the bug.
Done. https://bugs.eclipse.org/bugs/show_bug.cgi?id=483401
Quote:Quote:
Now the questions.
From Spec
From Spec
OK, I'll look into doing that.
Sorry, I was using an old version of the spec. The correct para number is 11.3.1.2, Figures 11.2 and 11.3.
visible : false;
OK, Thanks. That worked for the InitialNode and the ForkNode but not for the FinalNode.
Steve
Re: Activity Diagram bugs/questions [message #1716371 is a reply to message #1716153] |
Thu, 03 December 2015 05:03   |
Stephen Blackwell wrote on Tue, 01 December 2015 13:15
Quote:Quote:
Now the questions.
From Spec
From Spec
Great. Keep us informed!
The rake symbol should normally be displayed by default in papyrus for the callbehaviouractions. It is in my models at least. Could you describe in more detail what you do?
Re: Activity Diagram bugs/questions [message #1716853 is a reply to message #1716709] |
Tue, 08 December 2015 10:25  |
Stephen Blackwell wrote on Mon, 07 December 2015 11:28Quote:The rake symbol should normally be displayed by default in papyrus for the callbehaviouractions. It is in my models at least. Could you describe in more detail what you do?
The rake is disappearing when I change the default Behavior property to an Opaque Behavior. Is this supposed to happen?
Yes. Spec says
The call of an Activity is indicated by placing a rake-style symbol within the Action symbol
Since an opaque behaviour is not an activity, the rake symbol shouldn't be there...
Current Time: Sun Jul 20 06:18:51 EDT 2025
Powered by FUDForum. Page generated in 0.05556 seconds
