Home » Eclipse Projects » RCP Testing Tool » [SOLVED] Is Linux_framebuffer compatible with RCPTT ?(#Linux_framebuffer #compatible #rcptt #Jenkins)
icon7.gif  [SOLVED] Is Linux_framebuffer compatible with RCPTT ? [message #1710209] Mon, 05 October 2015 07:33 Go to next message
Dear all,
Do you know if Linux framebuffer
https://en.wikipedia.org/wiki/Linux_framebuffer
is compatible with RCPTT and Jenkins ?
I ask for this because probably I need to operate in a Linux machine without GUI.
Please let me know .
Thanks in advance.
[Updated on: Wed, 18 November 2015 11:20] by Moderator
Re: Is Linux_framebuffer compatible with RCPTT ? [message #1710212 is a reply to message #1710209] Mon, 05 October 2015 07:50 Go to previous messageGo to next message
Hi Angelo,
I'm not quite sure if it is related 100% to your question, but you can use headless linux for running UI tests. To do this, you need to install Xvnc.
Please see this article for more details (second part of it, after the basic Jenkins setup).
Kind regards,
Ulyana.
Re: Is Linux_framebuffer compatible with RCPTT ? [message #1710377 is a reply to message #1710212] Tue, 06 October 2015 06:40 Go to previous messageGo to next message
Hi Ulyana,
In my opinion are 2 different things.
I'll work in Linux machine without GUI (Only shell) and someone told me that it is possible to run test cases on that using Linux Framebuffer.
I'll let you know more details when I'll start to work on that just to be honest at the moment it is not clear to me.
Thank you.
Re: Is Linux_framebuffer compatible with RCPTT ? [message #1715035 is a reply to message #1710377] Wed, 18 November 2015 11:22 Go to previous message
Hi Folks,
I can confirm rcp tt is compatible with framebuffer to run test cases from Jenkins, I test it few minutes ago with a Linux Machine LTS with XFCE as window manager.
https://wiki.jenkins-ci.org/display/JENKINS/Xvfb+Plugin
Previous Topic:[SOLVED] Failed to execute goal org.eclipse.rcptt:rcptt-maven-plugin:2.0.0:execute
Next Topic:Unexpected results with RCPTT Runner
Current Time: Sat Jul 19 13:55:26 EDT 2025
Powered by FUDForum. Page generated in 0.03553 seconds
