[SOLVED] Failed to execute goal org.eclipse.rcptt:rcptt-maven-plugin:2.0.0:execute [message #1714928] |
Tue, 17 November 2015 12:16  |
Hi Folks,
I need to use rcp tt also from Linux Ubuntu machine.
If I run test cases from the shell (mvn clean compile) everything works.
When I run them from jenkins return an exception (Failed to execute goal org.eclipse.rcptt:rcptt-maven-plugin:2.0.0:execute (default-execute).
below the log file
NFO] The execution timeout is set to 3600 seconds
[INFO] Started at Tue Nov 17 17:56:11 CET 2015
[INFO] RCPTT Runner version: 2.0
[INFO] Initializing target platform...
[INFO] Target platform is valid.
[INFO] Looking for tests...
[INFO] Existing projects in workspace:
[INFO] <none>
[INFO] Importing projects to workspace:
[INFO] Refreshing projects:
[INFO] /home/admin/rcpttWorkspace/test_rcptt_linux/target/projects/productTests... OK
[INFO] test_rcptt_linux... OK
[INFO] Searching for tests in projects:
[INFO] Complete OK
[INFO] Testcase Artifacts:1
[INFO] AUT-0:Launching
[INFO] AUT-0:Product: org.eclipse.epp.package.testing.product
[INFO] AUT-0:Application: org.eclipse.ui.ide.workbench
[INFO] AUT-0:Architecture: x86_64
[INFO] 64bit arch is selected because AUT uses Equinox launcher
[INFO] - plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.300.v20150602-1417/
[INFO] /home/admin/rcpttWorkspace/test_rcptt_linux/target/aut-ws-0: AUT arguments: -os ${target.os} -arch ${target.arch} -consoleLog
[INFO] /home/admin/rcpttWorkspace/test_rcptt_linux/target/aut-ws-0: AUT VM arguments: -Dosgi.requiredJavaVersion=1.7 -XX:MaxPermSize=256m -Xms256m -Xmx1024m
[INFO] AUT-0: Launch failed. Reason: Process was terminated while waiting for AUT startup data
[INFO] AUT-0: For more information check AUT output at '/home/admin/rcpttWorkspace/test_rcptt_linux/target/results/aut-console-0_console.log'
[INFO] Failed to launch AUT:AUT-0: Launch failed. Reason: Process was terminated while waiting for AUT startup data
[INFO] Skip remaining: Execution finished
[INFO] Process terminated. Shut down AUTs
[INFO] Runner exit code is: 63
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 02:32 min
[INFO] Finished at: 2015-11-17T17:58:22+01:00
[INFO] Final Memory: 10M/303M
[ERROR] Failed to execute goal org.eclipse.rcptt:rcptt-maven-plugin:2.0.0:execute (default-execute) on project productTests: Failed to launch RCPTT runner: Runner exit code is: 63 -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.eclipse.rcptt:rcptt-maven-plugin:2.0.0:execute (default-execute) on project productTests: Failed to launch RCPTT runner
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:216)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:862)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:286)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:197)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.apache.maven.plugin.MojoExecutionException: Failed to launch RCPTT runner
at org.eclipse.rcptt.maven.ExecuteMojo.execute(ExecuteMojo.java:256)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
... 20 more
Caused by: org.apache.maven.plugin.MojoFailureException: Runner exit code is: 63
at org.eclipse.rcptt.maven.ExecuteMojo.execute(ExecuteMojo.java:249)
... 22 more
[ERROR]
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
java.net.ConnectException: Connection refused
[INFO] Process terminated. Send shutdown request to RCPTT runner.
Build step 'Invoke top-level Maven targets' marked build as failure
[htmlpublisher] Archiving HTML reports...
[Updated on: Wed, 18 November 2015 11:19] by Moderator
Re: [ERROR] Failed to execute goal org.eclipse.rcptt:rcptt-maven-plugin:2.0.0:execute (default-execu [message #1714993 is a reply to message #1714976] |
Wed, 18 November 2015 06:20   |
Hi Ulyana ,
thank you for your rapid answer.
Therefore, below the completed log and the pom file.
Started by user Angelo Luciani
[EnvInject] - Loading node environment variables.
Building in workspace /mnt/data/jenkins/workspace/test_rcptt
No emails were triggered.
[test_rcptt] $ mvn -f //home//admin//rcpttWorkspace//test_rcptt_linux//pom.xml clean compile
[INFO] Scanning for projects...
[INFO]
[INFO] Building productTests 2.0.0-SNAPSHOT
Downloading: https://repo.eclipse.org/content/repositories/rcptt-snapshots/org/apache/maven/plugins/maven-install-plugin/maven-metadata.xml
Downloading: https://repo.eclipse.org/content/repositories/rcptt-snapshots/org/apache/maven/plugins/maven-deploy-plugin/maven-metadata.xml
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ productTests ---
[INFO] Deleting /home/admin/rcpttWorkspace/test_rcptt_linux/target
[INFO]
[INFO] --- rcptt-maven-plugin:2.0.0:resources (default-resources) @ productTests ---
[INFO] Using AUT from /home/admin/Desktop/QA/eclipse
[INFO] Using RCPTT Runner from /home/admin/Desktop/QA/eclipse_runner
[INFO] Copying project contents to target directory...
[INFO]
[INFO] --- rcptt-maven-plugin:2.0.0:execute (default-execute) @ productTests ---
[INFO] Runner command line is /bin/sh -c cd /home/admin/Desktop/QA/eclipse_runner && /mnt/data/jenkins/tools/hudson.model.JDK/jdk7/jre/bin/java -Xmx1024m -XX:MaxPermSize=256m -jar /home/admin/Desktop/QA/eclipse_runner/plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar -application org.eclipse.rcptt.runner.headless -data /home/admin/rcpttWorkspace/test_rcptt_linux/target/runner-workspace -aut /home/admin/Desktop/QA/eclipse -autWsPrefix /home/admin/rcpttWorkspace/test_rcptt_linux/target/aut-ws- -autConsolePrefix /home/admin/rcpttWorkspace/test_rcptt_linux/target/results/aut-console- -q7report /home/admin/rcpttWorkspace/test_rcptt_linux/target/results/productTests.report -htmlReport /home/admin/rcpttWorkspace/test_rcptt_linux/target/results/productTests.html -junitReport /home/admin/rcpttWorkspace/test_rcptt_linux/target/surefire-reports/TEST-productTests.xml -import /home/admin/rcpttWorkspace/test_rcptt_linux/target/projects/productTests -testOptions 'execTimeout=3600;testExecTimeout=1800' -shutdownListenerPort 9972
[INFO] The execution timeout is set to 3600 seconds
[INFO] Started at Wed Nov 18 10:54:16 CET 2015
[INFO] <none>
[INFO] Complete OK
[INFO] Total time: 02:22 min
[INFO] Finished at: 2015-11-18T10:56:29+01:00
[INFO] Final Memory: 9M/239M
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[htmlpublisher] Archiving at PROJECT level /home/admin/rcpttWorkspace/test_rcptt_linux/target/results to /mnt/data/jenkins/jobs/test_rcptt/htmlreports/HTML_Report
POM FILE
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
<modelVersion>4.0.0</modelVersion>
<!-- Set artifact id according to a RCPTT project name -->
<artifactId>productTests</artifactId>
<!-- Set group id based on application under test name -->
<groupId>com.company.product</groupId>
<version>2.0.0-SNAPSHOT</version>
<!-- RCPTT Maven Plugin provides this packaging type -->
<packaging>rcpttTest</packaging>
<!-- RCPTT Maven Plugin and RCPTT Runner are hosted in this repository -->
<pluginRepositories>
<pluginRepository>
<id>rcptt-releases</id>
<name>RCPTT Maven repository</name>
<url>https://repo.eclipse.org/content/repositories/rcptt-releases/</url>
</pluginRepository>
<pluginRepository>
<id>rcptt-snapshots</id>
<name>RCPTT Maven Snapshots repository</name>
<snapshots>
<updatePolicy>always</updatePolicy>
</snapshots>
<url>https://repo.eclipse.org/content/repositories/rcptt-snapshots/</url>
</pluginRepository>
</pluginRepositories>
If RCPTT tests are planned to be run on an update site,
RCPTT Maven Plugin can download Eclipse SDK of required version
for current platform from repository below (to see
an up-to-date list of available versions visit this link:
http://maven.xored.com/nexus/content/repositories/ci4rcptt-releases/org/eclipse/sdk/
<properties>
<rcptt-maven-version>2.0.0</rcptt-maven-version>
</properties>
<!-- The main part of RCPTT Maven plugin -->
<build>
<plugins>
<plugin>
<groupId>org.eclipse.rcptt</groupId>
<artifactId>rcptt-maven-plugin</artifactId>
<version>${rcptt-maven-version}</version>
<extensions>true</extensions>
<configuration>
<!-- This element describes where to get an AUT to run tests -->
<aut>
<!-- There are several ways to specify AUT location,
Uncomment an element corresponding to a most suitable way
<!-- Use AUT from current build results. [classifier] will be
automatically replaced according to the current platform -->
<explicit>/home/admin/Desktop/QA/eclipse/</explicit>
<!-- Or specify a path to AUT folder -->
<explicit>/Users/RCPTTuser/path/to/aut</explicit>
<!-- As well AUT can be downloaded from HTTP -->
<explicit>http://server/path/aut-archive.zip</explicit>
<!-- AUT can be downloaded automatically from Maven repository -->
<artifactId>com.company.product.rcp</artifactId>
<version>3.7.2</version>
<!-- AUT Artifact classifier is based on a current platform:
Windows 32bit: win32.win32.x86
Windows 64bit: win32.win32.x86_64
Linux 32bit: linux.gtk.x86
Linux 64bit: linux.gtk.x86_64
Mac OS X 64bit: macosx.coca.x86_64
<!-- Optionally it is possible to specify extra features to
be installed into AUT, this is useful when RCPTT tests
need to be executed using a repository assembled as
part of current Maven build.
Inside an 'injection element it is possible to specify a list of
features/plugins to install, if nothing is set, all available
features will be installed.
feature.group suffix is required by p2,
otherwise it searches for a plugin with given id
Currently RCPTT Runner does not install requirements automatically,
so the full list of features to install must be explicitly set
<injections>
<!-- features are optional - when omitted, all features from given site will be installed -->
<injection>
<site></site>
<features>
<feature>com.comanyname.featureid</feature>
</features>
</injection>
</injections>
<!-- additional AUT args (besides taken in its ini-file) can be set
Use one argument per <arg> element -->
<args>
<arg>-ws</arg>
<arg>$${target.ws}</arg>
</args>
<!-- optional VM args can be set too -->
<vmArgs>
<vmArg>-Xmx768m</vmArg>
<vmArg>-XX:MaxPermSize=256m</vmArg>
</vmArgs>
</aut>
<runner>
<!-- RCPTT Runner location can be set using the same methods
as AUT location:
<explicit>/home/admin/Desktop/QA/eclipse_runner</explicit>
<!-- but the most convenient way is to just set its version,
RCPTT maven plugin will automatically set right groupId and
artifact ID and will download RCPTT Runner from Xored Maven Repo -->
<vmArgs>
<vmArg>-Xmx1024m</vmArg>
</vmArgs>
</runner>
<!-- Test options for RCPTT Runner, most popular options listed here.
Full list of options is available at:
https://ci.xored.com/doc/runner/
<testOptions>
<!-- Timeout for all tests, in seconds -->
<execTimeout>3600</execTimeout>
<!-- Timeout for a single test case, in seconds -->
<testExecTimeout>1800</testExecTimeout>
<!-- When set to true, in case of test failure
AUT will be restarted. This significantly
slows down execution, but may be useful
for some test suites -->
<restartAUTOnFailure>true</restartAUTOnFailure>
</testOptions>
<!-- By default RCPTT Runner runs tests from a project directory,
but in some cases it might be required to import additional
projects into runner's workspace -->
<projects>
<project>${project.basedir}/../project</project>
</projects>
<!-- By default RCPTT Runner runs all tests from workspace,
but it is possible to pass test suite names, so it
will execute only test suites from given project. -->
<suites>
<suite>MyTestSuite</suite>
</suites>
<!-- Sometimes it might be useful to skip a test case
(for instance because of some unresolved bug). RCPTT
can skip tests based on its tags. By default RCPTT skips
tests with tag 'skipExecution' (this value has been
chosen because on one hand it is descriptive enough,
on another hand it is unlikely that this tag name
will collide with some user's tag)
<skipTags>
<skipTag>linuxOnly</skipTag>
</skipTags>
<!-- By default RCPTT generates a single HTML report file with
all tests, but it is possible to generate one file per
test -->
<splitHtmlReport>true</splitHtmlReport>
</configuration>
</plugin>
</plugins>
</build>
</project>
FUDForum. Page generated in 0.05529 seconds
