Home » Modeling » Papyrus » How to improve graphics usage performance?(nearly unusable performance even with simple models)
How to improve graphics usage performance? [message #1714952] Tue, 17 November 2015 16:22 Go to next message
With Papyrus 1.1.2 on Mars.1 and openjdk 7, Debian-SID/KDE I experience a nearly unusable graphics performance.
Movement of shapes is not possible, because the graphics freezes after a short move.
Is this special on my machine or do you experience similar problems?
eclipse.ini contains:
-Dosgi.requiredJavaVersion=1.7
-XX:MaxPermSize=256m
-Xms256m
-Xmx2048m
Machine is i7 with 8GB and a SSD,
I had some improvement by closing almost all projects, however not significant.
Any idea for improvement welcome!
Re: How to improve graphics usage performance? [message #1714956 is a reply to message #1714952] Tue, 17 November 2015 17:22 Go to previous messageGo to next message
I have also noticed that the 1.1.2 version is very slow. I am running the Windows version on a 64bit i7 2.2Ghz machine with 12G of RAM and it can sometimes take several seconds to draw the properties pane. Part of the pane is drawn but I have to wait for the vertical scroll bar to be drawn.
It doesn't seem to happen all the time though.
Re: How to improve graphics usage performance? [message #1714969 is a reply to message #1714956] Wed, 18 November 2015 02:32 Go to previous messageGo to next message
Scenario: make a new profile project, a profile diagram, import metaclasses Package and StructuredClassifier to that diagram, Introduce 3 stereotypes, e.g. ModulePackage extends Package, ModuleCompositeClass extends StructuredClassifier, and Module specializes ModulePackage. Do something (Move ModuleCompositeClass araound (works slowly).) Select a metaclass. Wait ten seconds doing nothing. Nothing happens. Alt-tab to some other window and back: the metaclass gets selected, but the properties have not updated. This takes several seconds or window switches....
This happens not all the time. Sometimes it selects the metaclass after several seconds without window switching, sometimes you can wait for ages. Some racing condition?
What can I do if I can not find a work-around or a solution?
Re: How to improve graphics usage performance? [message #1714980 is a reply to message #1714969] Wed, 18 November 2015 04:36 Go to previous messageGo to next message
Hi Rolf and Stephen,
I haven't noticed any performance issue in the Mars versions. The only major issue we had was related to the Model Explorer's context menu, but this has been solved before the actual release.
I can't reproduce any of the issues you describe. Do you have some custom plug-ins installed? Since Papyrus is highly customizable, it is very easy to break general performances of the tool when doing some specific customizations (Especially for the Model Explorer's appearance)
You can also try closing the Outline view, which is known to be slow, especially when the diagram has scrollbars, or any other view that seems to update a lot during graphical operations. While the properties view is not extremely fast, it is expected to refresh under 200-300ms (Much less when selecting a similar element, e.g. from Stereotype1 to Stereotype2). However, the actual refresh of the properties view may also happen if all other views have been refreshed. So, if a foreign view is slow, it may prevent the properties view from updating.
Usually, closing all views one by one (starting with the Outline) is a good way to find the responsible
The Model Explorer - to - Diagram synchronization may also be slow, although the performances have improved a lot in the past releases. Do you use it? Does it help to switch it off?
Additionally, errors may prevent refresh operations entirely. In this case, the editors may seem slow because refresh will never happen. So you can check the error log view and see if anything is reported there. Eclipse also reports warnings in this view when the UI is frozen, so these warnings might help to identify the issue.
HTH,
Camille
Re: How to improve graphics usage performance? [message #1715001 is a reply to message #1714980] Wed, 18 November 2015 06:50 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type">
</head>
<div class="moz-cite-prefix">Hi<br>
<br>
Xtext has got more reactive to resource changes so it is possible
that if you have significant OCL / ALF / other textual content
then you may be doing many redundant reparses. Could this be your
scenario?<br>
<br>
    Regards<br>
<br>
        Ed Willink<br>
<br>
<br>
On 18/11/2015 09:36, Camille Letavernier wrote:<br>
</div>
<blockquote cite="mid:n2hgre$a6$1@xxxxxxxxe.org" type="cite">Hi
Rolf and Stephen,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
issue.
<br>
<br>
<br>
HTH,
<br>
Camille
<br>
</blockquote>
<br>
</body>
</html>
Re: How to improve graphics usage performance? [message #1715265 is a reply to message #1715001] Fri, 20 November 2015 11:35 Go to previous message
Found this bug report: [url=https://bugs.eclipse.org/bugs/show_bug.cgi?id=467279]
Steve
Previous Topic:Deadlock using TransactionalEditingDomain in Papyrus\CDO
Next Topic:Minor State Machine diagram bug
Current Time: Sun Jul 20 09:37:45 EDT 2025
Powered by FUDForum. Page generated in 0.03819 seconds
