Home » Newcomers » Newcomers » Error code 143(Solved!)
Error code 143 [message #1714619] Fri, 13 November 2015 22:39 Go to next message
I have been using eclipse for a couple months now, I am a student taking java classes. Everything was running fine until a recent system update back in the middle of October.
I am able to open eclipse, and that is about it. When I click on run nothing happens, and when I click on runas eclipse freezes, this is when i get error 143. The only way I am able to close it is with killall. Another thing I noticed is when I try to start a new java project, it also freezes after I click on next or finish. When i go to the preferences menu, not matter what I click on it stays on the first tab.
I am running 32bit archlinux
my default jre is openjdk7
I have attached the error log, although there is nothing in it, and the log from when I try to install with the new installer. It will go to a certain point and then undo everything and install fails.
I'm sure there is more info you need, just let me know.
  • Attachment: Eclipse.log
    (Size: 0.14KB, Downloaded 146 times)
  • Attachment: setup.log
    (Size: 126.62KB, Downloaded 176 times)
[Updated on: Tue, 17 November 2015 21:46] by Moderator
Re: Error code 143 [message #1714963 is a reply to message #1714619] Tue, 17 November 2015 21:45 Go to previous message
Ok, so the problem is fixed now! I am putting this here in case anyone is having a similar problem. It seems there is a problem with GTK3 and I don't know if it's just an Archlinux problem or not. I am submitting a report on it and see if it can be fixed.
I attached a link to the thread I found the answer from. All I needed to do was insert these two lines in "eclipse.ini"
--launcher.GTK_version
2
https://www.eclipse.org/forums/index.php?t=msg&th=1072144&goto=1714643&#msg_1714643
Previous Topic:All Eclipse Mars Dialogs Hang
Next Topic:SQL error #1:Invalid object name 'T_TRIRIGATABLE.
Current Time: Sun Jul 20 18:52:43 EDT 2025
Powered by FUDForum. Page generated in 0.08498 seconds
