Home » Archived » Eclipse Process Manager (Stardust) » How to delete wrong Rule Set (How to delete wrong Rule Set, not visible under "Navigation)
How to delete wrong Rule Set [message #1714044] Mon, 09 November 2015 09:30 Go to next message
obviously blocks a rule wit wrong syntax (after importing manipulated rule set json file) the activities:
15:22:46 WARN [080-exec-1] PhaseInterceptorChain - Application {http://rest.service.rules_manager.web.ui.stardust.eclipse.org/}RulesManagementResource has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: com.google.gson.JsonSyntaxException: com.google.gson.stream.MalformedJsonException: Unterminated array near [
"", true, "",
at org.apache.cxf.service.invoker.AbstractInvoker.createFault(AbstractInvoker.java:170)
I can not create any rule more...
How to delete such wrong rule sets ?
Michel
  • Attachment: capture.png
    (Size: 5.97KB, Downloaded 248 times)
[Updated on: Wed, 11 November 2015 02:24] by Moderator
Re: How to delete wrong Rule Set [message #1714697 is a reply to message #1714044] Mon, 16 November 2015 00:27 Go to previous message
Hi Michel,
To delete the wrong ruleset uploaded , you can navigate to the Administration->DocumentRepository Section and find the uploaded ruleset under rules folder and delete the required ruleset.
index.php/fa/23948/0/
Ashish
Previous Topic:Importing decision tables
Next Topic:View a Process Document
Current Time: Sun Jul 20 06:16:42 EDT 2025
Powered by FUDForum. Page generated in 0.04509 seconds
