Home » Modeling » EMF » [CDO] Startup error on linux getConfig().getBufferProvider() == null
[CDO] Startup error on linux getConfig().getBufferProvider() == null [message #1712853] Wed, 28 October 2015 15:19 Go to next message
I am trying to get some tests running which start an embedded cdo server with DBStore and H2 database. The tests are started by the maven\tycho build process.
The build runs without any problem on windows. But I encounter the following problem when running it from a Jenkins installed on Linux:
[INFO] Repository configuration manager extension started
[INFO] Net4j extension starting
[INFO] Net4j acceptor starting: tcp://0.0.0.0:2036
[ERROR] getConfig().getBufferProvider() == null
java.lang.IllegalStateException: getConfig().getBufferProvider() == null
	at org.eclipse.spi.net4j.Acceptor.doBeforeActivate(Acceptor.java:155)
	at org.eclipse.net4j.internal.tcp.TCPAcceptor.doBeforeActivate(TCPAcceptor.java:225)
	at org.eclipse.net4j.util.lifecycle.Lifecycle.internalActivate(Lifecycle.java:73)
	at org.eclipse.net4j.util.lifecycle.ShareableLifecycle.internalActivate(ShareableLifecycle.java:43)
	at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:162)
	at org.eclipse.net4j.TransportConfigurator.configureAcceptor(TransportConfigurator.java:108)
	at org.eclipse.net4j.TransportConfigurator.configure(TransportConfigurator.java:78)
	at org.eclipse.emf.cdo.server.internal.net4j.bundle.Net4jAppExtension.start(Net4jAppExtension.java:38)
I am a little stuck and do not know where to look. Any help would be appreciated.
Thorsten
Re: [CDO] Startup error on linux getConfig().getBufferProvider() == null [message #1712884 is a reply to message #1712853] Thu, 29 October 2015 04:19 Go to previous messageGo to next message
Hi Thorsten,
I have no idea why it would behave differently on Linux. If you enable tracing (see
https://wiki.eclipse.org/FAQ_for_CDO_and_Net4j#How_can_I_enable_tracing.3F ) do you get more hints on the problem?
Cheers
/Eike
http://www.esc-net.de
Am 28.10.2015 um 20:19 schrieb Thorsten Schlathölter:
> installed on Linux:
> Regards,
> Thorsten
Re: [CDO] Startup error on linux getConfig().getBufferProvider() == null [message #1713853 is a reply to message #1712884] Sat, 07 November 2015 02:58 Go to previous messageGo to next message
Seems to have been a configuration issue. The test is run as a plugin unit test and the launch config is derived from the dependencies. Meanwhile the server gets started by the test.
Thanks for the answer anyways.
Thorsten
Re: [CDO] Startup error on linux getConfig().getBufferProvider() == null [message #1848163 is a reply to message #1713853] Tue, 23 November 2021 02:27 Go to previous messageGo to next message
For me this was the solution:
Net4jUtil.prepareContainer(container);
Re: [CDO] Startup error on linux getConfig().getBufferProvider() == null [message #1848167 is a reply to message #1848163] Tue, 23 November 2021 03:56 Go to previous message
Net4jUtil.prepareContainer() is only useful if you run stand-alone (no extension registry available) or use a custom container (not IPluginContainer.INSTANCE).
When you use IPluginContainer.INSTANCE the extension registry automatically populates the container with the needed factory from the plugin.xml:
<factory
class="org.eclipse.internal.net4j.buffer.BufferPoolFactory"
productGroup="org.eclipse.net4j.bufferProviders"
type="default"/>
Previous Topic:Modeling Servlet in EMF
Next Topic:Copy&Paste between maps fails in Sample Ecore Editor
Current Time: Sun Jul 20 14:13:00 EDT 2025
Powered by FUDForum. Page generated in 0.03795 seconds
