Home » Eclipse Projects » RCP Testing Tool » [SOLVED] TestRunner all test cases failing(Failed to execute context: Close modal dialogs Cause: Failed to close dialogs)
[SOLVED] TestRunner all test cases failing [message #1705240] Thu, 13 August 2015 04:33 Go to next message
I keep running into an issue with my Test Runner test cases failing with the error message:
This error comes when I am running my .bat file from the command line.
"Failed to execute context: Close modal dialogs Cause: Failed to close dialogs".
This issue is happening continuously whenever i ran the .bat file.
I don't receive these errors when manually starting the same test suites with RCPTT.
Because of this not a single test case is running. All test cases becomes false.
Attached the html report.
Waiting for a reply.
  • Attachment: report.html
    (Size: 111.86KB, Downloaded 187 times)
[Updated on: Fri, 30 October 2015 22:31] by Moderator
Re: TestRunner all test cases failing [message #1709660 is a reply to message #1705240] Wed, 30 September 2015 03:12 Go to previous messageGo to next message
Hi Sabrine,
Is this "Load target platform" window appears when you start your AUT from RCPTT IDE?
Kind regards,
Ulyana.
Re: TestRunner all test cases failing [message #1712804 is a reply to message #1709660] Wed, 28 October 2015 07:03 Go to previous messageGo to next message
Hi Sabrine,
Could you please try RCPTT build from here (it should be finished in an hour) and check if the issue is fixed?
Kind regards,
Ulyana.
Re: TestRunner all test cases failing [message #1713104 is a reply to message #1712804] Fri, 30 October 2015 22:30 Go to previous message
Fixed in 2.1.0 nightly builds.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=478703
Previous Topic:[SOLVED] Not able to initiate test execution when Target platform initialization is in progress
Next Topic:Uninstall features through Maven Plugin
Current Time: Sun Jul 20 17:13:01 EDT 2025
Powered by FUDForum. Page generated in 0.30516 seconds
