Home » Modeling » TMF (Xtext) » Curious Error while using QuickFix(IDocumentExtension3 cannot be resolved (is indirectly referenced from required .class files))
Curious Error while using QuickFix [message #1712227] Thu, 22 October 2015 05:04 Go to next message
I am getting the following error in my editor, while using quickfix:
The type org.eclipse.jface.text.IDocumentExtension3 cannot be resolved. It is indirectly referenced from required .class files
This is my validator class:
class MyLanguageValidator extends AbstractMyLanguageValidator {
	public static final String UNCAPITALIZED_NAME = "my.language.quickfix.UncapitalizedName";
	@Check
	def checkNameIsUppercase(Element e) {
		if (!Character::isUpperCase(e.name.charAt(0))) {
			warning("Element name \"" + e.name + "\" should be capitalized.", null, MyLanguagePackage.ELEMENT__NAME, UNCAPITALIZED_NAME)
And this is my quickfix class:
public class MyLanguageQuickfixProvider extends DefaultQuickfixProvider {
	@Fix(MyLanguageValidator.UNCAPITALIZED_NAME)
	public void capitalizeName(final Issue issue,
			IssueResolutionAcceptor acceptor) {
		acceptor.accept(issue, "Capitalize element name",
				"Capitalize name of the element \"" + issue.getData()[0]
						+ "\".", "upcase.png", new IModification() {
					public void apply(IModificationContext context)
							throws Exception {
						IXtextDocument xtextDocument = context
								.getXtextDocument();
						String firstLetter = xtextDocument.get(
								issue.getOffset(), 1);
						xtextDocument.replace(issue.getOffset(), 1,
								firstLetter.toUpperCase());
I know, that such an error can occure unexpectedly in Eclipse and to solve it, it is necessary to remove and add the JRE System Library in the Java build path, inside the project's properties but unfortunately that doesn't help.
How can I solve the problem?
Re: Curious Error while using QuickFix [message #1712228 is a reply to message #1712227] Thu, 22 October 2015 05:08 Go to previous messageGo to next message
Hi John,
please make sure that you have the bundle org.eclipse.text on your
classpath.
Best,
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Find help at http://xtext.itemis.com or xtext(@)itemis.com
Blog: zarnekow.blogspot.com
Twitter: @szarnekow
Google+: https://www.google.com/+SebastianZarnekow
Re: Curious Error while using QuickFix [message #1712229 is a reply to message #1712228] Thu, 22 October 2015 05:37 Go to previous messageGo to next message
Hi Sebastian,
thank you very much for the quick response!
Fixed it! Many thanks!
[Updated on: Thu, 22 October 2015 05:38] by Moderator
Re: Curious Error while using QuickFix [message #1712249 is a reply to message #1712229] Thu, 22 October 2015 07:21 Go to previous messageGo to next message
On 22.10.15 11:37, John Cole wrote:
> Hi Sebastian,
> org.eclipse.text is inside the Plug-in Dependencies of my plugin
> project. The error is still there. Am I missing something else?
Hmm not that I'm aware of. Which version of eclipse.text is on your
classpath?
Sebastian
Twitter: @szarnekow
Re: Curious Error while using QuickFix [message #1712281 is a reply to message #1712249] Thu, 22 October 2015 11:47 Go to previous messageGo to next message
Hi Sebastian,
Christian suggested that I ask this question to you. The language I am working on contains entry methods, so the rule for an entry method may look like this:
Entry:
	  'entry' 'void' entryName=ID ep=EParameters code=CCode
CCode:  '[' -> ']'
The CCode can also contain braces as well. So basically whatever comes after EParameters which can be inside one of the three braces should be treated as CCode (which can include braces inside as well). How can I achieve this?
Re: Curious Error while using QuickFix [message #1712344 is a reply to message #1712249] Fri, 23 October 2015 04:22 Go to previous messageGo to next message
Sebastian Zarnekow wrote on Thu, 22 October 2015 11:21
classpath?
Sebastian,
first of all, thank you very much for the quick and excellent support!
I am using Version 2.4.3 and I still don't understand, why there is an EAttribute missing in the Literals. Here is an example DSL:
Element:
	'Element' name=ID
	description=STRING?
	('firstParameter' firstParameter=DOUBLE)
	('subelement' subelement=[Subelement])
	'end' 'Element'
Subelement:
	'Subelement' name=ID
	description=STRING?
	('secondparameter' secondparameter=DOUBLE)
	'end' 'Subelement'
This is how it is used:
Element MyElement
	"This is my element"
	firstParameter 1.2
	subelement MySubelement
end Element
Subelement MySubelement
	"This is my subelement"
	secondparameter = 3.5
end Subelement
In my Validator I want to reference the name=ID, so the string "MyElement". I am trying to do the following:
String PREFIX = "my.language.";
String UNCAPITALIZED_ENTITY_NAME = "UncapitalizedEntityName";
public void checkElementNameStartsWithCapital(Element element) {
		if (!Character.isUpperCase(element.getName().charAt(0))) {
			warning("Uncapitalized name",
					MyLaguagePackage.Literals.ELEMENT__NAME,
					IssueCodes.UNCAPITALIZED_ENTITY_NAME,
					element.getName());
But ELEMENT__NAME is not visible, only ELEMENT__SUBELEMENT.
Is it possible to reference the name? What am I doing wrong?
Re: Curious Error while using QuickFix [message #1712345 is a reply to message #1712344] Fri, 23 October 2015 04:35 Go to previous messageGo to next message
Depending on your grammar it might be ANCESTOR_OF_ELEMENT__NAME (have a look at the Element interface, where is the getName method in the type hierarchy)
[Updated on: Fri, 23 October 2015 04:41] by Moderator
Re: Curious Error while using QuickFix [message #1712346 is a reply to message #1712345] Fri, 23 October 2015 04:36 Go to previous messageGo to next message
p.s.: please open new topics for ne question (especially for you (->) problem
Re: Curious Error while using QuickFix [message #1712348 is a reply to message #1712345] Fri, 23 October 2015 04:59 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 23 October 2015 08:35
True, it works if I want to reference name=ID of Element but how can I reference Subelement? And in case Subelement has an SubSubElement, and so on?
This is the Grammer starting from root element:
Model:
	components+=Component*
Component:
	Element | Subelement
Element:
	'Element' name=ID
	description=STRING?
	'end' 'Element'
Subelement:
	description=STRING?
	'end' 'Subelement'
... and the extended validator:
					MyLaguagePackage.Literals.COMPONENT__NAME,
					element.getName());
		if (!Character.isUpperCase(element.getSubelement().getName().charAt(0))) {
					MyLaguagePackage.Literals.COMPONENT__NAME,	// ???
					element.getSubelement().getName());
I am sure, I will be able to apply awareness on my whole dsl, if you could help me referencing subelements. Smile
Re: Curious Error while using QuickFix [message #1712355 is a reply to message #1712348] Fri, 23 October 2015 05:20 Go to previous messageGo to next message
yes component__name looks right.
please note that ref=[Type] is short for ref=[Type|ID] which means an ID will be parsed.
so you may want to
ref=[Type|FQN]
with
FQN:ID ("." ID)*;
Re: Curious Error while using QuickFix [message #1712364 is a reply to message #1712355] Fri, 23 October 2015 06:17 Go to previous messageGo to next message
Hm... but COMPONENT_NAME doesn't seem to be right while using subcomponents. So the second if-statement has no effects:
So if I say...
Element MyElement
	firstParameter 1.2
	subelement mysubelement
end Element
Subelement mysubelement
end Subelement
... mysubelement is not underlined and no warning appears.
Re: Curious Error while using QuickFix [message #1712367 is a reply to message #1712364] Fri, 23 October 2015 06:32 Go to previous messageGo to next message
i dont know your complete grammar. simply underline the thing you want to underline.
the name of the feature is always
NAME_OF_THE_CLASS_THAT_HOLDS_THE_FEATURE__NAME_OF_THE_FEATURE
so have a look which java class contains the feature and use the corresponding feature.
Re: Curious Error while using QuickFix [message #1712368 is a reply to message #1712367] Fri, 23 October 2015 06:33 Go to previous messageGo to next message
and as i said:
you should ever ever ever ever specify the object as well !!!!
if you dont the object will implcitely the parameter of the check method
Re: Curious Error while using QuickFix [message #1712371 is a reply to message #1712368] Fri, 23 October 2015 06:39 Go to previous message
p.p.s: and what do you actually want to underline.
and shouldnt that check be defined for subelement instead?
Previous Topic:Generate multiple new project wizards
Next Topic:strange eclipse behavior in multi module project
Current Time: Sun Jul 20 08:46:53 EDT 2025
Powered by FUDForum. Page generated in 0.05228 seconds
