Stardust installed, but it is not showing up? [message #1712297] |
Thu, 22 October 2015 13:04  |
Relatively new to Eclipse, and completely new to Stardust, so I'll self-describe as a newbie on this one.
Windows 7.
I've installed Eclipse (Mars release), and it appears to be working correctly. I then used the online install mechanism to install Stardust (Help->Install New Software, etc., etc.). That install appeared to go correctly, and when I go back and look at the packages installed in Eclipse, the "Process Model" stuff is all in there, so it appears that Eclipse knows the Stardust components are present.
However, none of the Stardust stuff appears anywhere in the Eclipse UI. For instance, when I try to add the Servers View called "Process Manager" doesn't exist. Also, when I try to create a new Dynamic Web Project, the Configuration option "Stardust Portal for Dynamic web module 2.5" is not available.
Any ideas?
Thanks!!
--Al
FUDForum. Page generated in 0.03933 seconds
