Home » Archived » Eclipse Process Manager (Stardust) » Showing Documents using a manual activity
Showing Documents using a manual activity [message #1711039] Mon, 12 October 2015 09:48 Go to next message
This is a query related to using Documents on Stardust.
I created a manual activity and added a document in this activity. However, when I try to show this document by sending this as an input to another activity. I couldn't see it.
Is it the right way of using/showing the documents?
Note:Model attached.
Ajay
  • Attachment: Model12.xpdl
    (Size: 33.61KB, Downloaded 335 times)
Re: Showing Documents using a manual activity [message #1711077 is a reply to message #1711039] Mon, 12 October 2015 14:08 Go to previous messageGo to next message
Hi Ajay,
This can be done with DMS operation, you can refer to below tutorial
http://help.eclipse.org/mars/topic/org.eclipse.stardust.docs.dms/html/dms/dms-examples.html?resultof=%22%64%6f%63%75%6d%65%6e%74%22%20%22%61%63%74%69%76%69%74%79%22%20%22%61%63%74%69%76%22%20
Tanmoy Roy
Re: Showing Documents using a manual activity [message #1711151 is a reply to message #1711077] Tue, 13 October 2015 09:35 Go to previous messageGo to next message
Hi Tanmoy,
Thanks for the tutorial. I successfully imported the xpdl attached inside it in my browser modeler. However, after deploying it, all the initial activities (Add Document, Get Document, Update Document) are all showing in "Completed" status and they are not available for the user to do any action on them.
Could you please check if it works like this way?
Ajay
Re: Showing Documents using a manual activity [message #1711191 is a reply to message #1711151] Wed, 14 October 2015 01:10 Go to previous messageGo to next message
Hi Ajay,
As activities Add Document/Get Document/Update Document are application activities. And application activities don't require any user intervention so those will be completed automatically. you should be able to see only manual activites.
What is your exact requirement ? do you want user to upload documunets from manual activity and display that document in next manual activity ?
-Thanks
Re: Showing Documents using a manual activity [message #1711331 is a reply to message #1711191] Thu, 15 October 2015 01:46 Go to previous messageGo to next message
Hi Tanmoy,
That is exactly what I want to do - User to upload documunets from manual activity and display that document in next manual activity.
Ajay
Re: Showing Documents using a manual activity [message #1711341 is a reply to message #1711331] Thu, 15 October 2015 03:01 Go to previous messageGo to next message
Check attached model XPDL if that helps you.
-Thanks
  • Attachment: Document.xpdl
    (Size: 30.38KB, Downloaded 317 times)
Re: Showing Documents using a manual activity [message #1711346 is a reply to message #1711341] Thu, 15 October 2015 04:26 Go to previous messageGo to next message
Hi Rajkumar,
Thanks! This one worked perfectly for an activity.
However, if I want to pass this uploaded document's path or the document itself to a UI mashup app, is there a way out?
I tried to pass the document as Input to a UI mashup app, but it seems document types are not supported yet in it.
Ajay
Re: Showing Documents using a manual activity [message #1711702 is a reply to message #1711346] Mon, 19 October 2015 07:38 Go to previous messageGo to next message
Could you please check my below query.
Ajay
Re: Showing Documents using a manual activity [message #1713206 is a reply to message #1711702] Mon, 02 November 2015 06:31 Go to previous messageGo to next message
Which query is mentioned here, if your issue is not resolved, would you mind giving the exact question again.
Re: Showing Documents using a manual activity [message #1713215 is a reply to message #1713206] Mon, 02 November 2015 08:01 Go to previous message
Hi Vikram,
The exact query is :
I want to show the attached process document on a new tab of a browser using some URL ( which may contain document Id etc.). So, how can I make that URL or its already available in Stardust IPP.
Ajay
Previous Topic:Problems to deploy the ACME Workflow Model from the Support Example tutorial
Next Topic:Import Type Declarations exception
Current Time: Sat Jul 19 18:18:43 EDT 2025
Powered by FUDForum. Page generated in 0.04997 seconds
