Home » Modeling » EMF » [CDO] Unable to login with security enabled([CDO] Unable to login with security enabled)
[CDO] Unable to login with security enabled [message #1711595] Sat, 17 October 2015 17:49
I have enabled security for the CDO Server and have created a user and a session for that user with the CDO workbench. When I try to create a session from my application I get the following exception:
Caused by: org.eclipse.net4j.util.lifecycle.LifecycleException: Could not activate TCPClientConnector[localhost:2,036]
at org.eclipse.net4j.util.container.ManagedContainer.activateElement(ManagedContainer.java:355)
at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:325)
at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:301)
at org.eclipse.net4j.tcp.TCPUtil.getConnector(TCPUtil.java:65)
at com.peacemkr.config.app.emf.DomainImpl.openSession(DomainImpl.java:170)
at com.peacemkr.config.app.emf.DomainImpl.getSession(DomainImpl.java:71)
My understanding from Tom Schindl's tutorial is that adding a credentials provider before creating a session was all that had to be done before creating a session. Did I miss something?
This is the code I am using to create the session.
private CDONet4jSession openSession(String repoName) {
PasswordCredentialsProvider credentialsProvider = new PasswordCredentialsProvider("user", "password");
IPluginContainer.INSTANCE.addPostProcessor(new ConnectorCredentialsInjector("localhost:2036",credentialsProvider));
final IConnector connector =TCPUtil.getConnector(IPluginContainer.INSTANCE, "localhost:2036");
CDONet4jSessionConfiguration config = CDONet4jUtil
.createNet4jSessionConfiguration();
config.setConnector(connector);
config.setRepositoryName(repoName);
CDONet4jSession session = config.openNet4jSession();
session.addListener(new LifecycleEventAdapter() {
protected void onDeactivated(ILifecycle lifecycle) {
connector.close();
System.out.println("CDO Session Deactivated");
return session;
Thank You,
Greg Babcock
Previous Topic:[CDO] query on a view other than latest
Next Topic:problem when instantiating in emf
Current Time: Sun Jul 20 03:43:16 EDT 2025
Powered by FUDForum. Page generated in 0.03468 seconds
