Problem first test with Maven [message #1704980] |
Tue, 11 August 2015 05:03  |
Hi all,
I`m trying to integrate RCPTT tests on Jenkins with rcptt-maven-plugin for continuous integration but I'm facing a problem in Jenkins, when maven executes our AUT that runs a CDO Server at the beginning and RCPTT doesn't wait for its complete initialization (when the modal dialog "Starting Server" disappears). Instead of that, RCPTT closes by default all dialogs at the beginning. Is there any option or configuration to override this behaviour? Can we wait for this dialog or for any dialog instead of closing them?
Is it possible that rcptt-maven-plugin waits for a process?
PS: I tried putting a script context try catch in the first launching test but sometimes fail. I tested with delay times too with the same result
Marta Alvarez
Re: Problem first test with Maven [message #1711448 is a reply to message #1711276] |
Fri, 16 October 2015 04:15  |
Hi Marta,
I have the same problem than you. My tests run on Jenkins in a Windows Machine. My RCP start with a modal window, and the test fail because RCPTT can not close the modal window or wait to modal window is closed.
Curiously, if i don't use rpctt maven plugin and run the test interactively with RCPT Tool, I have no problem, so hope that the problem is fixed soon.
FUDForum. Page generated in 0.04339 seconds
