Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [ECP] DiagnosticView
[ECP] DiagnosticView [message #1711146] Tue, 13 October 2015 08:50 Go to next message
Hi there,
I installed the (highly experimental) DiagnosticView for e4 from the ecp
1.7 update site (http://www.eclipse.org/ecp/download.html)
Is there any example available that shows how to register the view in
the e4 application model and then actually showing any validation results?
As both, a e4- and ecp-beginner, the link between my e4-part that holds
the EMF Forms view and the e4-part that holds the DiagnosticView is not
clear to me.
So far I managed to set the application model up so that an empty
DiagnosticView Table is shown (I see a grid and column titles).
If the usage is discouraged: Is there any e4 alternative to show
validation results?
So far I use org.eclipse.emf.common.ui.dialogs.DiagnosticDialog,
however, it seems to have dependencies to some e3 stuff as it throws
exceptions when opening details. Additionally it is quite limited.
Is there any other approach also to create some link to an EMF forms
view, e.g. to set focus to an errorneous entry in the EMF Forms tree view?
Hauke
Re: [ECP] DiagnosticView [message #1711219 is a reply to message #1711146] Wed, 14 October 2015 03:46 Go to previous message
this feature is currently in an experimental state. We use it internally
for projects, but we have not yet published API and documentation. Also,
no ready-to-use integration with EMF Forms is available, yet. However,
it would not be too much effort to do this. Are you interested in
sponsoring this?
Best regards
Jonas
Am 13.10.2015 um 14:50 schrieb Hauke Fuhrmann:
> Hi there,
> clear to me.
> validation results?
> Cheers,
> Hauke
Jonas Helming
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Previous Topic:[EMF Forms] Validation results in Tree View
Next Topic:[Edapt] Using edapt for generated Ecore models
Current Time: Sun Jul 20 12:18:14 EDT 2025
Powered by FUDForum. Page generated in 0.03568 seconds
