Any info on stable release with resolution of current bugs is gratefully received! [message #1709448] |
Mon, 28 September 2015 09:04  |
Hi there so as you can probably guess from my several posts, I have been evaluating papyrus for past couple of weeks and in my install (1.1 on Windows 7) I have some show-stopper bugs:
- Sequence diagrams and deployment diagrams are unusable (see my previous posts)
- Notes and graphical objects are unusable
I'm starting my project today and sadly the conclusion is that I cannot use Papyrus with current limitations. If anyone has info on when these issues will be solved and a fully working release will be available please let me know!
Papyrus seems to be shaping up to a fantastic tool, so it would be great if I can entrust my projects to it.
Re: Any info on stable release with resolution of current bugs is gratefully received! [message #1711142 is a reply to message #1710935] |
Tue, 13 October 2015 08:37   |
As indicated in the Mars roadmap, we are still working hard on the tests and non-regressions tests on Papyrus project. We are also constantly improving the way the committers work together, so we can go for more bug reduction, as for example using the AERI tool to see which errors are found by our users.
The sequence diagram developments were kind of complex, as this diagram is a specific one (strict layout, different concept than the usual node - link / container contained relationships). We have a modernization task about sequence diagram running for Neon release, that can be also reported to Mars release if possible: 474048: [Sequence Diagram] Should be generated with latest version of generators
https://bugs.eclipse.org/bugs/show_bug.cgi?id=474048. This will give us a chance to fix lots of bugs on this diagram coming from its specific architecture.
In the meantime, we are very intereted to have some feedback from our users, and try to answer as fast as we can. Please fill free to report any bug you have on the diagrams, and check if the bugs are still present in the coming release.
Rémi
Re: Any info on stable release with resolution of current bugs is gratefully received! [message #1731408 is a reply to message #1715667] |
Wed, 04 May 2016 22:15  |
Hello
it's great to see Papyrus improvements in Tables and I read that even more are coming in the Neon release. Looking forward to it!
I am evaluating Papyrus 2.0.0 nightly build and I think it's still impossible to word wrap text on classifiers in any diagram. There are a few bugs marked 'Assigned' on Bugzilla about this, one of them is 361852.
It would be great if this got resolved in Neon! Cheers
Ri Fr wrote on Wed, 25 November 2015 07:40Coming back to this topic, I excluded Papyrus from my current project due to issues mentioned in my previous posts. Looking at 2016 projects, It would be helpful if I have some indications on plans to fix following issues either in current or next release (I could not find any info on papyrus homepage): I have submitted relative bug / enhancement reports via Bugzilla
- Word wrap on Classifiers in diagrams
- CSS setting to have all Edges point to the center of Classifiers instead of some point on the periphery of Classifier
- CSS setting to remove the "Imported" squiggle on Classifiers in diagrams
- Paste from Excel / Import from Excel into Nat Table works for generic tables
- Nat tables have a column showing the Classifier type (so the table can be sorted/filtered by Classifier type)
- Activity Diagrams have option to draw swimlanes horizontally
- SysML is an add-on Component to Papyrus, not integral part
Thank you to Papyrus developers and let me know if any info! Cheers
FUDForum. Page generated in 0.04118 seconds
