Eclipse vanished [message #1711100] |
Mon, 12 October 2015 23:19  |
Has anyone been using Eclipse successfully on a Macbook Pro, and had it seem to vanish? I ran the following in Terminal, saw where Eclipse might be located, but did not see it there.
Has anyone else been able to solve this problem without reinstalling? If I do so, Eclipse might disappear again, though, because I don't know why this happened. If Mac deletes it, does anyone know why or what to change? There are quite a few folders under Home but I do not see the Eclipse application anywhere. There is not anything that I can see named Sandis-MBP.
sandidooley$ echo $(/usr/libexec/java_home)
/Library/Java/JavaVirtualMachines/jdk1.8.0_60.jdk/Contents/Home
Sandis-MBP:~ sandidooley$
Thanks (a newbie)
Re: Eclipse vanished [message #1711308 is a reply to message #1711268] |
Wed, 14 October 2015 15:56  |
Just Eclipse, not java.
I also have Netbeans and am using that with java. Another class will be using Eclipse, so I will be using both on the same laptop (worked fine for awhile, which is why I am thinking maybe it is something else i.e. mac directory issue I cannot see, because I looked in the Eclipse folders, though I could have easily not looked in the right place). When I find out what it is, hopefully without just reinstalling (because it might happen again), I will post. Thanks for asking.
FUDForum. Page generated in 0.07711 seconds
