Home » Archived » Eclipse Process Manager (Stardust) » UI Mashup Example
UI Mashup Example [message #1710396] Tue, 06 October 2015 08:22 Go to next message
Hi Stardust Team
I tried your UI Mashup example : http://help.eclipse.org/mars/topic/org.eclipse.stardust.docs.dev/html/examples/tutorials/mashup/mashup.zip
However, I was unable to deploy the xpdl on the browser modeler. Also while testing the UI mashup application inside the process, the structured data was not getting populated on the angular Ui page showDispute.html.
Could you please help me out in this?
Ajay
Re: UI Mashup Example [message #1711037 is a reply to message #1710396] Mon, 12 October 2015 09:40 Go to previous messageGo to next message
You can refer below example:
https://wiki.eclipse.org/Stardust/Knowledge_Base/Integration/UI/UIMashup/FormValidation
-RajKumar
Re: UI Mashup Example [message #1711038 is a reply to message #1711037] Mon, 12 October 2015 09:46 Go to previous message
Hi RajKumar,
Thanks for the example. I will go through it.
Ajay
Previous Topic:Angular JS based UI mashup example
Next Topic:camel trigger as start event
Current Time: Sat Jul 19 19:43:19 EDT 2025
Powered by FUDForum. Page generated in 0.29792 seconds
