Eclipse Luna problem with Run Configuration [message #1710961] |
Sun, 11 October 2015 22:02 |
I am trying to run an RCP application in Eclipse Luna. I create a new Run Configuration and select Run a program under the main tab, and then select the product I wish to run and hit apply. However, if I hit run I get an error: "No application id has been found" and sure enough upon checking my Run Configuration again, there is no product selected.
No matter what settings I change under the Main tab, my product to run gets deselected as soon as I close the Run Configurations window. I have tried different versions of Eclipse (started with Luna for RCP applications and then tried Luna for Java Developers), so I don't think it's a problem with Eclipse itself, probably some small oversight on my part. Any ideas or helpful advice would be greatly appreciated, I have no idea what could be causing this, this same project works fine on my other machine as well as several other peoples' machines. If that is relevant I am running it on Windows 7 64-bit Service Pack 1.
FUDForum. Page generated in 0.03524 seconds
