Home » Archived » Eclipse Process Manager (Stardust) » Decision Tables / Actions(Action = get / put dateafrom / to other application)
Decision Tables / Actions [message #1710673] Thu, 08 October 2015 06:15 Go to next message
is it possible to define an action like get / put data from / to other application ?
If yes: how ?
In not: is there any workaround / best practices to do it ?
Thanks a lot in advance,
Michel
[Updated on: Thu, 08 October 2015 09:46] by Moderator
Re: Decision Tables / Actions [message #1710723 is a reply to message #1710673] Thu, 08 October 2015 12:35 Go to previous messageGo to next message
Hi Michel,
What exactly do you mean by "other application", can you elaborate a bit, do you mean other platform? other application types within stardust?.
-Vikram
Re: Decision Tables / Actions [message #1710767 is a reply to message #1710723] Fri, 09 October 2015 03:18 Go to previous messageGo to next message
Hi Vikram,
the "other application" is outside of startdust. Communication over SOAP over HTTPS.
Warm regards, Michel
Re: Decision Tables / Actions [message #1711032 is a reply to message #1710767] Mon, 12 October 2015 09:37 Go to previous message
Did you tried stardust "Web Service Application" for consuming the SOAP services ?
http://help.eclipse.org/mars/index.jsp?topic=%2Forg.eclipse.stardust.docs.analyst%2Fhtml%2Fhandbooks%2Fmodelling_analyst%2Fapplications%2Fpep-application-web-service.htm&resultof=%22web%20service%20application%22%20
-RajKumar
Previous Topic:JMS Trigger - Type for incoming MapMessage
Next Topic:Angular JS based UI mashup example
Current Time: Sun Jul 20 07:23:15 EDT 2025
Powered by FUDForum. Page generated in 0.04202 seconds
