Home » Eclipse Projects » Requirements Modeling Framework  » Glossary desc/type reversed in tree
Glossary desc/type reversed in tree [message #1710653] Thu, 08 October 2015 04:39 Go to next message
In my project, I have a Glossary specification, with entries of Glossary Type (Spec Object) underneath.
Currently I have the Glossary entry (to create the columns) and a single other Glossary spec object for user.
However, when I use this structure, I find that the Description and Term columns appear to be reversed - instead of seeing the term in the tree Outline, I see the description. This seems counter intuitive - I would want to look down the Glossary tree for a term, to see the meaning.
Can this be replicated, without destroying the Column meanings for Term and Description?
Re: Glossary desc/type reversed in tree [message #1710676 is a reply to message #1710653] Thu, 08 October 2015 06:36 Go to previous messageGo to next message
Hi Max,
You can configure the attribute names to be used for labels via fmStudio | Label Configuration | Default Label.
More details here: http://formalmind.com/handbook?page=sec-general_configuration.html
Best,
- Michael
PS: I think I still owe you another answer. Smile
Re: Glossary desc/type reversed in tree [message #1710677 is a reply to message #1710676] Thu, 08 October 2015 06:57 Go to previous message
I see this now - under General Configuration. I needed to add Term as a default label and then rate it up, ahead of Description.
many thanks!
Previous Topic:What datatype required for Glossary?
Next Topic:Image support?
Current Time: Sat Jul 19 19:44:58 EDT 2025
Powered by FUDForum. Page generated in 0.03405 seconds
