Error while setting up Stardust 3.0.1 with MySQL 5.6 [message #1710086] |
Sun, 04 October 2015 02:37  |
I am new to Eclipse Stardust and would really like to learn it. I did some setup for Stardust and crated the ipp stardust war file for tomcat using maven archetype and created the MySQL Database for it to use using sysconsole. When I startup tomcat it gives me an error. I read stardust 3.0.1 supports MySQL 5.6 but there seems to be some issue when I start. Can someone please help as really want to use Stardust.
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'jmsForkingService' defined in ServletContext resource [/WEB-INF/config/ipp/spring/carnot-spring-jms-context.xml]: Invocation of init method failed; nested exception is org.eclipse.stardust.common.error.PublicException: : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'partition FROM daemon_log WHERE (daemon_log.code = 0 AND daemon_log.stamp > 0)' at line 1
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1482)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:521)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:458)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:295)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:292)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:628)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:932)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:479)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:389)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:294)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:112)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4973)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5467)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1559)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1549)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.eclipse.stardust.common.error.PublicException: : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'partition FROM daemon_log WHERE (daemon_log.code = 0 AND daemon_log.stamp > 0)' at line 1
at org.eclipse.stardust.engine.core.persistence.jdbc.Session.executeQuery(Session.java:2609)
at org.eclipse.stardust.engine.core.persistence.jdbc.Session.executePersistentQuery(Session.java:2816)
at org.eclipse.stardust.engine.core.persistence.jdbc.Session.getIterator(Session.java:1434)
at org.eclipse.stardust.engine.core.persistence.jdbc.Session.getIterator(Session.java:1408)
at org.eclipse.stardust.engine.api.spring.AbstractSpringForkingServiceBean$1.execute(AbstractSpringForkingServiceBean.java:72)
at org.eclipse.stardust.engine.api.spring.AbstractSpringForkingServiceBean$TxIsolatedActionInvoker.isolate(AbstractSpringForkingServiceBean.java:259)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.CallingInterceptor.invoke(CallingInterceptor.java:29)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.proceed(MethodInvocationImpl.java:130)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.POJOExceptionHandler.invoke(POJOExceptionHandler.java:30)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.RuntimeExtensionsInterceptor.invoke(RuntimeExtensionsInterceptor.java:34)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.NonInteractiveSecurityContextInterceptor.invoke(NonInteractiveSecurityContextInterceptor.java:47)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.doWithDataSource(SpringSessionInterceptor.java:142)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.access$000(SpringSessionInterceptor.java:48)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor$1.doInConnection(SpringSessionInterceptor.java:87)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:342)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.invoke(SpringSessionInterceptor.java:81)
at org.eclipse.stardust.engine.api.spring.SpringConfigurationInterceptor.invoke(SpringConfigurationInterceptor.java:101)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.PropertyLayerProviderInterceptor.invoke(PropertyLayerProviderInterceptor.java:129)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor.invoke(DebugInterceptor.java:56)
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor$1.doInTransaction(SpringTxInterceptor.java:93)
at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:131)
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor.invoke(SpringTxInterceptor.java:71)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.execute(MethodInvocationImpl.java:68)
at org.eclipse.stardust.engine.core.runtime.beans.InvocationManager.invoke(InvocationManager.java:53)
at com.sun.proxy.$Proxy56.isolate(Unknown Source)
at org.eclipse.stardust.engine.api.spring.AbstractSpringForkingServiceBean$2.doInTransaction(AbstractSpringForkingServiceBean.java:156)
at org.eclipse.stardust.engine.api.spring.AbstractSpringForkingServiceBean.isolate(AbstractSpringForkingServiceBean.java:137)
at org.eclipse.stardust.engine.api.spring.AbstractSpringForkingServiceBean.afterPropertiesSet(AbstractSpringForkingServiceBean.java:68)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1541)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1479)
... 21 more
Caused by: com.mysql.jdbc.exceptions.MySQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'partition FROM daemon_log WHERE (daemon_log.code = 0 AND daemon_log.stamp > 0)' at line 1
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:936)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:2985)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1631)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1723)
at com.mysql.jdbc.Connection.execSQL(Connection.java:3277)
at com.mysql.jdbc.Connection.execSQL(Connection.java:3206)
at com.mysql.jdbc.Statement.executeQuery(Statement.java:1232)
at com.mysql.jdbc.jdbc2.optional.StatementWrapper.executeQuery(StatementWrapper.java:705)
at org.tranql.connector.jdbc.StatementHandle.executeQuery(StatementHandle.java:49)
at org.eclipse.stardust.engine.core.persistence.jdbc.Session.executeQuery(Session.java:2600)
... 63 more
Oct 04, 2015 11:59:05 AM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
... 21 more
... 63 more
11:59:05 INFO [tartStop-1] tupServletContextListener - MyFaces already initialized
11:59:05 INFO [tartStop-1] tupServletContextListener - ServletContext '/home/rakesh/workspace/.metadata/.plugins/org.eclipse.wst.server.core/tmp0/wtpwebapps/stardust-portal-3.0.1/' initialized.
Oct 04, 2015 11:59:05 AM org.apache.catalina.core.StandardContext startInternal
SEVERE: Error listenerStart
SEVERE: Context [/stardust-portal-3.0.1] startup failed due to previous errors
11:59:06 INFO [tartStop-1] ContextEventRepeater - Servlet Context Name: SunGard CSA LLC - IPP Portal, Server Info: Apache Tomcat/7.0.52 (Ubuntu)
Oct 04, 2015 11:59:06 AM org.apache.catalina.core.ApplicationContext log
INFO: Closing Spring root WebApplicationContext
Oct 04, 2015 11:59:06 AM org.apache.catalina.loader.WebappClassLoader clearReferencesJdbc
SEVERE: The web application [/stardust-portal-3.0.1] registered the JDBC driver [com.mysql.jdbc.Driver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
Oct 04, 2015 11:59:06 AM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads
SEVERE: The web application [/stardust-portal-3.0.1] appears to have started a thread named [RetryTimer] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/stardust-portal-3.0.1] appears to have started a thread named [PoolIdleReleaseTimer] but has failed to stop it. This is very likely to create a memory leak.
SEVERE: The web application [/stardust-portal-3.0.1] appears to have started a thread named [MySQL Statement Cancellation Timer] but has failed to stop it. This is very likely to create a memory leak.
Oct 04, 2015 11:59:06 AM org.apache.catalina.loader.WebappClassLoader checkThreadLocalMapForLeaks
SEVERE: The web application [/stardust-portal-3.0.1] created a ThreadLocal with key of type [com.sun.xml.bind.v2.ClassFactory$1] (value [com.sun.xml.bind.v2.ClassFactory$1@4c24db30]) and a value of type [java.util.WeakHashMap] (value [{class javax.xml.bind.annotation.adapters.CollapsedStringAdapter=java.lang.ref.WeakReference@7b2535e, class org.apache.camel.spring.CamelContextFactoryBean=java.lang.ref.WeakReference@4c7f4444}]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [/stardust-portal-3.0.1] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@375af398]) and a value of type [org.eclipse.stardust.common.config.ParametersFacade] (value [org.eclipse.stardust.common.config.ParametersFacade@342e9c8c]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [/stardust-portal-3.0.1] created a ThreadLocal with key of type [org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor.ThreadLocalSqlTimeRecorder] (value [org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor$ThreadLocalSqlTimeRecorder@6027c617]) and a value of type [org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor.RecorderData] (value [org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor$RecorderData@533e4152]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
Oct 04, 2015 11:59:06 AM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-10080"]
Oct 04, 2015 11:59:06 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 28455 ms
FUDForum. Page generated in 0.26161 seconds
