Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Forms] Cannot edit models in Forms
[EMF Forms] Cannot edit models in Forms [message #1710176] Mon, 05 October 2015 04:07 Go to next message
Hi there,
I'm doing my first steps with EMF-Forms and have some problems with the
e4-Example application.
I adapted the code a little bit to support my own model (Xtext based)
and in the Part I set a correct EMF-Model that I loaded from a EMF
resource (actually loaded from an Xtext parsed file).
So far so good, my contents is correctly shown in the forms-editor.
Below is the code.
The problem is that I cannot change the model. If I manually edit any
String-Field in the editor, the change is immediately discarded when I
close and reopen that view. If I add an object to a list I get an NPE
like the one below.
Did I miss anything to enable edit support?
Hauke
EList<EObject> input;
@PostConstruct
public void createComposite(Composite parent) {
this.parent = parent;
content = new Composite(parent, SWT.NONE);
try {
content.setBackground(parent.getDisplay().getSystemColor(SWT.COLOR_WHITE));
content.setLayout(GridLayoutFactory.fillDefaults().margins(10,
10).create());
content.setLayoutData(GridDataFactory.fillDefaults().create());
if (input == null || input.isEmpty())
return;
final ViewModelContext vmc =
ViewModelContextFactory.INSTANCE.createViewModelContext(
ViewProviderHelper.getView(input.get(0), null), input.get(0), new
DefaultReferenceService());
ECPSWTViewRenderer.INSTANCE.render(content, vmc);
content.layout();
} catch (final ECPRendererException e) {
e.printStackTrace();
parent.layout();
at
org.eclipse.emf.ecp.internal.edit.ECPControlHelper.addModelElementInReference(ECPControlHelper.java:44)
at
org.eclipse.emf.ecp.ui.view.swt.DefaultReferenceService.addNewModelElements(DefaultReferenceService.java:120)
at
org.eclipse.emf.ecp.view.internal.control.multireference.MultiReferenceSWTRenderer.handleAddNew(MultiReferenceSWTRenderer.java:428)
at
org.eclipse.emf.ecp.view.internal.control.multireference.MultiReferenceSWTRenderer$2.widgetSelected(MultiReferenceSWTRenderer.java:269)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at
org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:159)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Re: [EMF Forms] Cannot edit models in Forms [message #1710323 is a reply to message #1710176] Tue, 06 October 2015 02:37 Go to previous message
seems like there is no EditingDomain for your model instance. You can
attach it to the ressource your EObjects are contained in.
Best regards
Jonas
Am 05.10.2015 um 10:07 schrieb Hauke Fuhrmann:
> at
Jonas Helming
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Previous Topic:[ECP] Custom E4 Application
Next Topic:[EMF Forms] render views read-only dynamically
Current Time: Sat Jul 19 21:57:25 EDT 2025
Powered by FUDForum. Page generated in 0.04004 seconds
