Paste into Papyrus table not working for UML? Or I'm doing something wrong? [message #1710138] |
Mon, 05 October 2015 00:53  |
Hi there
following these instructions, Papyrus 1.2.0 (I just updated)
I want to import a list of Packages into and existing package
Select the Package - new table - generic Table
Select the Table - Properties - Paste: "Not available for this Table" (contrary to what the user guide says)
Then I get a bunch of error messages from papyrus (I clicked 'Yes' on 'Submit bug report') such as 'An error has occurred. See error log for more details.
java.lang.NullPointerException'
Tried to paste anyway, nothing happens
Try again!!!
Select the Package - new table - generic Tree Table
Select the Table - Properties - now Paste view is showing
Delect 'Detach mode'
Paste element ID select 'org.eclipse.papyrus.uml.Package'
Containment feature: 'PackageableElement'
Select the table, Create/Destroy Columns', select UML 'Package', 'Name'
Go back to the table, copy the Package names from Excel table (a few cells in a column), click on Table, Edit - Paste , nothing happens. Click on the 'name' column, Edit-paste, nothing happens. Is this a bug or am I doing it wrong? Thanks!!!
p.s. "Import from file" context menu is available on Generic tables, and it only generates error messages for me - nothing else...
[Updated on: Mon, 05 October 2015 01:29] by Moderator
Re: Paste into Papyrus table not working for UML? Or I'm doing something wrong? [message #1710234 is a reply to message #1710222] |
Mon, 05 October 2015 09:07  |
Thank you Camille and Vincent
Yes I tried to configure the Generic Table to receive the right Element; when I do this, I cannot access the 'Paste' property for Generic table, and nothing happens when I try to paste; I *can* access the 'paste' property for *Generic Tree* Table, however nothing happens when I paste. I think as Vincent says the tool to do this has not yet been created. p.s. Import from Excel also not working, so it would be great if we could kill 2 birds with 1 stone!
FUDForum. Page generated in 0.04269 seconds
