Home » Eclipse Projects » Eclipse Platform » Eclipse 3.0M4 - I am not told anymore about not being able to replace running code.
Eclipse 3.0M4 - I am not told anymore about not being able to replace running code. [message #170938] Tue, 16 December 2003 08:00 Go to next message
Originally posted by: use.reply.to.invalid
We do a lot of hot code replacement, and I use the "could not replace
code" to tell me that I need to restart (which is a heavy weight process).
At one time I misclicked and now it does not tell me anymore. According
to preferences I have all the necessary options enabled, so I apparently
need to do something else.
Where am I to look?
Thorbjoern Ravn Andersen "...plus...Tubular Bells!"
Re: Eclipse 3.0M4 - I am not told anymore about not being able to replace running code. [message #170946 is a reply to message #170938] Tue, 16 December 2003 08:21 Go to previous messageGo to next message
If you have reenabled the hot code replace preferences under
Window>Preferences>Java>Debug>Hot Code Replace and you still do not see the
dialogs then please file a bug report with a reproducible test case against
JDT Debug.
Darins
"Thorbj
Re: Eclipse 3.0M4 - I am not told anymore about not being able to replace running code. [message #170979 is a reply to message #170946] Tue, 16 December 2003 09:12 Go to previous messageGo to next message
> JDT Debug.
Be happy to if I can reenable it in my current setup :) Any suggestions?
Re: Eclipse 3.0M4 - I am not told anymore about not being able to replace running code. [message #171058 is a reply to message #170979] Tue, 16 December 2003 11:59 Go to previous messageGo to next message
>> see the
>> against
>> JDT Debug.
Ended up deleting .metadata and redoing my configuration. Quite tedious
but it fixed the problem for now. If it shows up again, I'll take heed
and file the bug report.
Re: Eclipse 3.0M4 - I am not told anymore about not being able to replace running code. [message #171336 is a reply to message #171058] Tue, 16 December 2003 17:03 Go to previous messageGo to next message
Originally posted by: jaredburns.acm.org.nospam
Why didn't you just click on the checkbox that Darin suggested?
- Jared
>>> see the
>>> against
>>> JDT Debug.
Re: Eclipse 3.0M4 - I am not told anymore about not being able to replace running code. [message #171621 is a reply to message #171336] Wed, 17 December 2003 09:54 Go to previous message
Because it was already checked. Should I have clicked it twice?
Previous Topic:JVM crashes on exit.
Next Topic:CVS problem: Invalid resource name
Current Time: Sat Jul 19 13:42:14 EDT 2025
Powered by FUDForum. Page generated in 0.04973 seconds
