Home » Archived » B3 » Producing a maven repository with B3( Problem with the generated groupId)
Producing a maven repository with B3 [message #1708087] Sat, 12 September 2015 08:56 Go to next message
I am trying to produce a maven repository using a P2 repository as source. See: Creating a Maven-conformant p2 repo
My goal is to obtain a maven repository containing some of the jars released by the mylyn-wikitext project. Bug 421551 is opened for that, but until it is solved, I need a workaround.
It is important to notice that there is already a repository containing snaptshots:
https://repo.eclipse.org/content/repositories/mylyn-snapshots/
I have published my initial results on bintray (webviewer).
My problem is that the groupId generated by b3 (org.eclipse.mylyn) is not similar to what can be found in the snaptshots repository (org.eclipse.mylyn.docs).
Dependency to wikitext.core in the snaptshots repo:
    <dependency>
      <groupId>org.eclipse.mylyn.docs</groupId>
      <artifactId>org.eclipse.mylyn.wikitext.core</artifactId>
      <version>2.5.0-SNAPSHOT</version>
    </dependency>
Dependency to wikitext.core in the repo created with b3:
    <dependency>
      <groupId>org.eclipse.mylyn</groupId>
      <version>2.5.0.v20150522-1430</version>
    </dependency>
Did I miss something?
Is there a possibility to set the maven groupId in the b3aggr file (to override the generated one)?
My work is shared on github:
https://github.com/jmini/mylyn-wikitext-repository
Re: Producing a maven repository with B3 [message #1709082 is a reply to message #1708087] Wed, 23 September 2015 15:37 Go to previous messageGo to next message
All I need is already present in the B3 tool! The construct I was looking for is called Maven Mapping.
I did not verify it completely yet, but I think that my problem will be solved with this maven mapping:
index.php/fa/23336/0/
I hope I will be able to create a real workaround for Bug 421551 with this approach. I will let you know.
Re: Producing a maven repository with B3 [message #1709201 is a reply to message #1709082] Thu, 24 September 2015 16:16 Go to previous messageGo to next message
MavenMapping was the solution for my use case. More details on what I got in bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=421551#c11
I have updated the b3aggr files in my GitHub repository (Example: mars.b3aggr)!
Thank you a lot for the Eclipse B3 Tool.
Re: Producing a maven repository with B3 [message #1709206 is a reply to message #1709201] Thu, 24 September 2015 17:41 Go to previous message
> got in bugzilla:
> https://github.com/jmini/mylyn-wikitext-repository/blob/master/aggregator/mars.b3aggr)!
Thank YOU for answering your own questions :-)
- henrik
Previous Topic:Proxying Maven central
Next Topic:maven result with strictMavenVersions : invalid version numbers in maven-metadata.xml
Current Time: Sun Jul 20 19:43:52 EDT 2025
Powered by FUDForum. Page generated in 0.04709 seconds
