Home » Archived » BIRT » Rotate Text with Barcode.The Text (itemnum) below barcode gets truncated at bottom(Itemnum below the barcode when displayed vertically in BIRT 232 getting truncated at the bottom)
Rotate Text with Barcode.The Text (itemnum) below barcode gets truncated at bottom [message #1708866] Tue, 22 September 2015 00:57 Go to next message
Hi Everyone,
I need a help.Kindly avise
I am using Birt 232. I need to display barcode with itemnum,description and storeroom vertically.So I have created a table with four columns and placed ROTATE TEXT from plattte(installed JAR) in four columns.I have used Barcode Font(IDAutomationHC39M Free Version Regular)with Rotate Text which will display Barcode with Itemnum below vertically.
My Issue is the itemnum which comes below the barcode gets truncated (little cut at the bottom)while viewing in the report viewer or pdf..I have attached the pdf for ur reference.
I tried several options like giving margin to the data column , padding to the rotate text element , margin to the rotate text but still the same effect.
Can anyone help me with this issue urgently???Kindly refer the pdf.
Is there any property to set the text properly when using rotate text with barcode?
Thanks in advance.
Re: Rotate Text with Barcode.The Text (itemnum) below barcode gets truncated at bottom [message #1708953 is a reply to message #1708866] Tue, 22 September 2015 14:23 Go to previous messageGo to next message
Moving this to the BIRT forum.
Re: Rotate Text with Barcode.The Text (itemnum) below barcode gets truncated at bottom [message #1709343 is a reply to message #1708953] Sun, 27 September 2015 01:07 Go to previous messageGo to next message
Hi Everyone.
Very Urgent!!! Can anyone help or advise me on this please?
Re: Rotate Text with Barcode.The Text (itemnum) below barcode gets truncated at bottom [message #1739588 is a reply to message #1708866] Wed, 03 August 2016 03:20 Go to previous message
Hi, did you get a work around for this?
I am checking on how to print barcode vertically? I am unable to do Sad
Previous Topic:Create and Arrange Grids per Row dynamically
Next Topic:SCRIPT HELP
Current Time: Sun Jul 20 16:11:23 EDT 2025
Powered by FUDForum. Page generated in 0.03731 seconds
