Home » Eclipse Projects » DTP » Data Source Explorer shows Informix schemas empty(When browsing an Informix database no table is expanded on any schema but system ones under Informix schema)
Data Source Explorer shows Informix schemas empty [message #874976] Mon, 21 May 2012 18:12 Go to next message
Hello.
I can't browse tables for a given schema in Informix using Eclipse Data Source Explorer. The only tables I can browse is the catalog, the sys* ones in the Informix schema.
I'm using Eclipse v3.6 (Helios) with Data Tools Project plugin v1.9.2 for accessing an Informix 11.70 database. The driver (v10.0) and the connection configuration seem to be right as I can ping and query properly using the SQL scrap book, creating and selecting tables. In fact the applications work perfectly once deployed, but I'm unable to use Eclipse features such as JPS tools. The user has the proper access and is able to browse and operate anything from Server Studio.
I've searched Google for a few days and found some cases expriencing something alike (for instance it can happen in MySQL if you're missing the database in the URL), but found no proper answer.
Thanks in advance
P.S.: I've created a test project that illustrates the problem. Notice the "Tables" node can't be expanded. i.stack.imgur.com/F2u4w.png
Edit: typo
Edit 2: Rewrite for clarifying
[Updated on: Thu, 24 May 2012 06:52] by Moderator
Re: Data Source Explorer shows Informix schemas empty [message #899267 is a reply to message #874976] Tue, 31 July 2012 05:19 Go to previous messageGo to next message
The same problem. Eclipse Indigo 3.7.2, MySQL 5.5, DTP 1.9.2
Re: Data Source Explorer shows Informix schemas empty [message #1708355 is a reply to message #899267] Tue, 15 September 2015 15:59 Go to previous messageGo to next message
I am seeing the same thing with Eclipse Luna.
Has anyone worked on this issue or gotten it to work?
Re: Data Source Explorer shows Informix schemas empty [message #1708777 is a reply to message #1708355] Mon, 21 September 2015 00:08 Go to previous messageGo to next message
Have you got it resolved?
Re: Data Source Explorer shows Informix schemas empty [message #1708818 is a reply to message #1708777] Mon, 21 September 2015 09:42 Go to previous messageGo to next message
No, I haven't
Re: Data Source Explorer shows Informix schemas empty [message #1708957 is a reply to message #1708818] Tue, 22 September 2015 15:41 Go to previous message
I no longer have access to that project and environment so I can't tell.
Previous Topic:Dependancy Issues - requires 'bundle org.eclipse.core.runtime [3.2.0,4.0.0)'
Next Topic:Advanced Pl Sql Concepts In Oracle
Current Time: Sat Jul 19 15:55:23 EDT 2025
Powered by FUDForum. Page generated in 0.04757 seconds
