Multiple workspace with same product [message #1708563] |
Thu, 17 September 2015 09:25  |
Currently the installer (in advanced mode) ask for eclipse product, then projects setup.
If I want to create several workspaces with same product and projects (with different project stream), it seems I have to install one eclipse per workspace, as the eclipse itself is supposed to be indentical for all workspaces.
I would like to create one eclipse for all the workspaces. What is the best way to do this ?
is setting same eclipse path install and checking overwrite is ok ?
Another question. Is it possible to add projects setup on a already installed eclipse ?
Re: Multiple workspace with same product [message #1708576 is a reply to message #1708563] |
Thu, 17 September 2015 11:13   |
Arnaud,
In any Eclipse installation where Oomph has already been installed, you
can use File -> Import... -> Oomph -> Projects into Workspace to add a
project setup to that specific workspace.
Of course using bundle pools multiple installations are very tiny, so
having one installation per workspace is not really a problem. In any
case, using the above approach, you can open a new workspace in an
existing installation and add project setups to that workspace.
On 17/09/2015 3:25 PM, Arnaud MERGEY wrote:
> Hello,
> best way to do this ? is setting same eclipse path install and
> installed eclipse ?
FUDForum. Page generated in 0.04963 seconds
