Home » Modeling » EMF » reduce loading time of an xmi file
reduce loading time of an xmi file [message #1707436] |
Fri, 04 September 2015 13:17  |
I want to load an XMI file and get its content. My code works but the loading is taking a lot of time (1hour). I tried to modify the load options but it did not solve the problem.
The code is below:
static EObject loadXMI(String instancePath, EmfModelReader reader)
//load model instance
ResourceSetImpl load_resourceSet = new ResourceSetImpl();
load_resourceSet.getLoadOptions().put(XMIResource.OPTION_DEFER_IDREF_RESOLUTION, Boolean.TRUE);
load_resourceSet.getLoadOptions().put(XMIResource.OPTION_DEFER_ATTACHMENT, Boolean.TRUE);
load_resourceSet.getLoadOptions().put(XMIResource.OPTION_USE_DEPRECATED_METHODS, Boolean.TRUE);
load_resourceSet.getLoadOptions().put(XMIResource.OPTION_USE_PARSER_POOL, new XMLParserPoolImpl());
load_resourceSet.getLoadOptions().put(XMIResource.OPTION_USE_XML_NAME_TO_FEATURE_MAP, new HashMap());
load_resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl());
// reader.getPackages().get(0): returns the EPackage of the core model
load_resourceSet.getPackageRegistry().put(reader.getPackages().get(0).getNsURI(),reader.getPackages().get(0));
Resource load_resource = load_resourceSet.getResource(URI.createURI(instancePath),true);
EList<EObject> elements= load_resource.getContents();
return elements.get(0);
Re: reduce loading time of an xmi file [message #1707441 is a reply to message #1707436] |
Fri, 04 September 2015 13:53   |
Using binary rather than ASCII serialization can give a significant
benefit, but it also inhibits many opportunities to evolve the metamodel.
If you really want to load XMI much faster the following approach is on
my to-do list.
Auto-generate an LPG parser from the metamodel with direct EObject
setXXX action code.
This should replace the generic SAX callbacks by an efficient
metamodel-specific state machine and bypass the many levels of EMF/XMI
flexibility.
If you know that you only want part of the model, a partial load could
be autogenerated as well.
Ed Willink
On 04/09/2015 18:17, Ameni BF wrote:
> Hello,
> options but it did not solve the problem. The code is below:
> static EObject loadXMI(String instancePath, EmfModelReader reader) {
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> new HashMap());
Re: reduce loading time of an xmi file [message #1707455 is a reply to message #1707436] |
Fri, 04 September 2015 15:05   |
This post is almost devoid of useful information. How big is the XMI
file 2K? 2G? 10G? If it's taking an hour, it's unlikely that XMI is
a good representation for whatever gigantic thing you're loading. If
you want to know why it's taking so long, you'll need to use a profiler...
On 04/09/2015 7:17 PM, Ameni BF wrote:
> Hello,
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> new HashMap());
Re: reduce loading time of an xmi file [message #1708454 is a reply to message #1707436] |
Wed, 16 September 2015 12:18  |
Ameni,
Using
org.eclipse.emf.ecore.resource.impl.ResourceImpl.setIntrinsicIDToEObjectMap(Map<String,
EObject>) in the resource factory along with
OPTION_DEFER_IDREF_RESOLUTION (which you're already doing would also
have helped a lot). This way the resource is traversed once, after the
entire resource is loaded, to build an ID to EObject map, which can then
very efficiently resolve each ID.
> Hello,
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> new HashMap());
Current Time: Sat Jul 19 20:06:43 EDT 2025
Powered by FUDForum. Page generated in 0.04528 seconds
