Home » Eclipse Projects » RCP Testing Tool » Subject closed : Configuration Maven 3.1.1 and Maven plugin rcptt(Subject closed)
icon14.gif  Subject closed : Configuration Maven 3.1.1 and Maven plugin rcptt [message #1707880] Thu, 10 September 2015 03:52 Go to next message
I have a problem with the configuration between Maven 3.1.1 and RCPTT maven plugin for the version 1.5.5 or 1.5.6.
The problem results from a conflict with Java 7.
I changed well the pom.xml of my application to execute the algorithm SHA1 and not SHA256. And I changed the pom.xml for run the 1.5.5 (or 1.5.6) rcptt runner
But during the execution, I have errors on the fact that it does not find the algorithm.
You will find as attachment the part of my pom.xml and the .log file returned after execution.
Thank for help Smile
I reviewed the configuration file of Maven (settings.xml)
[Updated on: Fri, 11 September 2015 10:40] by Moderator
Re: Subject closed : Configuration Maven 3.1.1 and Maven plugin rcptt [message #1709519 is a reply to message #1707880] Tue, 29 September 2015 02:52 Go to previous message
Hi Ker rek,
Are you still experiencing the problem?
Could you pleas try RCPTT 2.0 version and check the result?
Kind regards,
Ulyana.
Previous Topic:Possible to implement a search in the assertions window?
Next Topic:[SOLVED] Working with Dynamic variables [Get the tab name ]
Current Time: Sun Jul 20 05:33:24 EDT 2025
Powered by FUDForum. Page generated in 0.04149 seconds
