Home » Newcomers » Newcomers » Where to go for assistance with CVS plugin(Where to go for assistance with CVS plugin)
Where to go for assistance with CVS plugin [message #1707609] Mon, 07 September 2015 18:06 Go to next message
Hello. I have a problem wherein the Eclipse CVS plugin has broken in my Eclipse installation. I do not know which room to go to ask for help fixing it. I described the problem at stackoverflow.com/q/32405510/.
Thanks for your help.
[Updated on: Mon, 07 September 2015 18:07] by Moderator
Re: Where to go for assistance with CVS plugin [message #1707624 is a reply to message #1707609] Tue, 08 September 2015 00:19 Go to previous messageGo to next message
It's usually better to describe it here if you want an answer here.
While using a workspace with projects from CVS, you've changed from an installation that had the CVS feature installed to one that doesn't. It may have been removed in the current version of whatever package you downloaded as CVS is declining in popularity. So go install the CVS feature from the Mars Update Site: http://download.eclipse.org/releases/mars/.
Re: Where to go for assistance with CVS plugin [SOLVED] [message #1707672 is a reply to message #1707624] Tue, 08 September 2015 09:04 Go to previous message
Nitin Dahyabhai wrote on Tue, 08 September 2015 04:19
Thanks a million. That worked. Smile
[Updated on: Tue, 08 September 2015 09:04] by Moderator
Previous Topic:UML Diagram by using Eclipse
Next Topic:Where is the SDK Manager Icon?!
Current Time: Sun Jul 20 03:15:54 EDT 2025
Powered by FUDForum. Page generated in 0.10853 seconds
