Home » Eclipse Projects » EclipseLink » Lazy loading is not triggered in front-end, though static weaving is enabled
Lazy loading is not triggered in front-end, though static weaving is enabled [message #1707424] Fri, 04 September 2015 11:34 Go to next message
When an entity has been passed to the front-end, and becomes detached, normally you cannot retrieve an unitialized, lazy-loaded list. Though, EclipseLink does support this feature, thanks to it's weaving.
We've used this feature heavily in our application, which was deployed on Weblogic.
Now, we are making the switch to JBoss EAP 6.3. Initializing uninitialized lists on detached entities no longer seem to work.
We've activated static weaving. (added the property in persistence.xml + added a maven plugin to do the weaving at compile time).
This seems to work fine.
When we start debugging, we see the following happen. The code here is the decompiled result after weaving:
Entity Organzation has a lazy-loaded list locations.
We call, on a detached Organization, the method getLocations():
@OneToMany(cascade={CascadeType.ALL}, mappedBy="organization")
    public List<OrganizationLocation> getLocations() {
        return this._persistence_get_locations();
Organization => _persistence_get_locations()
public List _persistence_get_locations() {
        this._persistence_checkFetched("locations");
        return this.locations;
AbstractDomainClass =>_persistence_check_fetched("locations")
public void _persistence_checkFetched(String string) {
        if (!this._persistence_isAttributeFetched(string)) {
            EntityManagerImpl.processUnfetchedAttribute((FetchGroupTracker)this, (String)string);
AbstractDomainClass => _persistence_isAttributeFetched("locations")
public boolean _persistence_isAttributeFetched(String string) {
        return this._persistence_fetchGroup == null || this._persistence_fetchGroup.containsAttributeInternal(string);
Organization =>_persistence_fetchGroup == null is TRUE
AbstractDomainClass. _persistence_isAttributeFetched("locations") is TRUE
So nothing gets loaded!
Does anyone have any idea why _persistence_fetchGroup could be null? We don't have any fetchGroups specified, but it should have a default one, no?
We've tested this with EclipseLink 2.5.1, 2.5.2 and 2.6.0.
Re: Lazy loading is not triggered in front-end, though static weaving is enabled [message #1707591 is a reply to message #1707424] Mon, 07 September 2015 13:36 Go to previous messageGo to next message
Was the entity serialized somehow? Serialization can occur within the same JVM container and would prevent the entity from referencing the context it was read from to trigger unfetched relationships.
icon14.gif  Re: Lazy loading is not triggered in front-end, though static weaving is enabled [message #1707593 is a reply to message #1707591] Mon, 07 September 2015 13:49 Go to previous message
You are right. The EJB's themselves got serialized.
Instead of referencing to them with @EJB, they were put in a Spring Context and retrieved through the FacesContext instance. Getting rid of this strange construction and using local EJB's solved the problem.
EclipseLink is doing what was promised!
This thread can be closed.
Previous Topic:Getting a naming exception for a DataSource that I can find programatically
Next Topic:EclipseLink not using Tomcat JDBC Connection Pool?
Current Time: Sun Jul 20 18:02:11 EDT 2025
Powered by FUDForum. Page generated in 0.03848 seconds
