Home » Modeling » EMF » Different Validation for a model
Different Validation for a model [message #1707102] Wed, 02 September 2015 06:50 Go to next message
Hi there,
I try to use the same EMF ecore-Model in different contexts, i.e. in
different Eclipse RCP-Products. Each product might have slightly
different business rules under which I want to validate the model.
Is it somehow possible to decouple the EMF validation from the
implementation of the validating methods in order to separate model and
validation rules into separate bundles? Or would that be something I'd
have to add myself, i.e. some mechanism by eclipse extension points to
search for registered validation bundles that validate the model?
Hauke
Re: Different Validation for a model [message #1707109 is a reply to message #1707102] Wed, 02 September 2015 08:19 Go to previous messageGo to next message
If you use OCL you can separate your validation into OCL documents.
Different applications can select which Complete OCL documents are used.
Ed Willink
On 02/09/2015 11:50, Hauke Fuhrmann wrote:
> Hi there,
> and validation rules into separate bundles? Or would that be something
> I'd have to add myself, i.e. some mechanism by eclipse extension
> points to search for registered validation bundles that validate the
> model?
> Cheers,
> Hauke
Re: Different Validation for a model [message #1707332 is a reply to message #1707109] Thu, 03 September 2015 15:34 Go to previous messageGo to next message
Alternatively, you can use EMF Validation Framework. It provides an ability to write constraints as Java/OCL code, provide them via plugin.xml and split you constraints between bundles.
Re: Different Validation for a model [message #1707362 is a reply to message #1707109] Fri, 04 September 2015 03:07 Go to previous messageGo to next message
Hi Ed,
thanks for pointing to OCL. I wrote a Complete OCL file now, which
worked fine for my model. However, I do not find much information how to
connect the ecore with the OCL file. I.e. I want to express that the
usual EMF validation should delegate to this OCL validation using my OCL
file.
Did not find any extension point for that.
The documentation only briefly describes
"The CompleteOCLEObjectValidator is used to enable Complete OCL
documents to participate in the validation processing of an Xtext editor.
The APIs for merging Complete OCL and Ecore as intermediate Pivots and
then migrating the Pivot back to Ecore are experimental."
As I have no Xtext model but a plain ecore file, I'm a little lost how
to actually connect the things such that the validation can be used from
the usual ecore-tree-editor and pop up in the problem view.
Any hints where to look?
Hauke
Re: Different Validation for a model [message #1707402 is a reply to message #1707362] Fri, 04 September 2015 09:29 Go to previous messageGo to next message
I found a recipe for my use case in the Eclipse wiki. Very glad for that.
I follow this recipe to connect my custom Ecore file with my custom
ocl-File: http://wiki.eclipse.org/EMF/Validation/Recipes
However, the recipe suggests to reuse some example projects which
results in having three additional projects with 9 Java classes and a
lot of plugin.xml config (e.g. editorActions) to glue everything
together. This is quite some unexpected overhead boilerplate code from
my point of view.
Is this really the way to use an CompleteOCL file?
Any opinion appreciated.
Hauke
Am 04.09.2015 09:07, schrieb Hauke Fuhrmann:
> Hi Ed,
> file.
> Cheers,
> Hauke
Re: Different Validation for a model [message #1707411 is a reply to message #1707402] Fri, 04 September 2015 10:36 Go to previous message
No.
You will get on much better by following the up-to-date material in the
OCL documentation.
The wiki is a valiant effort in 2008 to make sense of a seriously
prehistoric approach. I did some minor repair work in 2012 to refer to
the OCLinEcore editor.
But this is not the way to go. See my reply on the OCL newsgroup.
Ed Willink
> my point of view.
> Cheers,
> Hauke
>> Hi Ed,
>> file.
>> editor.
>> Cheers,
>> Hauke
Previous Topic:EReference Tree
Next Topic:How to change encoding ascii to utf-8
Current Time: Sun Jul 20 07:08:13 EDT 2025
Powered by FUDForum. Page generated in 0.03716 seconds
