Home » Eclipse Projects » EclipseLink » Entity is not updated
Entity is not updated [message #1707046] Tue, 01 September 2015 15:39 Go to next message
Hi all,
I've an abstract Document entity which has a "deleted" attribute:
@Entity()
@Table(name = "FKT_DOCUMENT")
@Inheritance(strategy = InheritanceType.JOINED)
@EntityListeners(value = { EntityListener.class })
public abstract class Document extends ModelObject implements IEntity,
Serializable {
@Basic()
@Column(name = "DELETED")
private Boolean deleted = Boolean.FALSE;
public Boolean getDeleted() {
return deleted;
public void setDeleted(Boolean newDeleted) {
firePropertyChange("deleted", this.deleted, newDeleted);
deleted = newDeleted;
// ... some additional getters and setters
Another class inherits from this entity:
@Entity()
@Table(name = "FKT_INVOICE")
@PrimaryKeyJoinColumns({ @PrimaryKeyJoinColumn(name =
"INVOICE_PARENT_ID") })
public class Invoice extends Document {
// ...some other getters and setters
Now, if I set the "deleted" attribute to another value and call save()
(or update()) with EntityManager, the entity is not updated (it seems
that the trigger for putting the object in the changeSet from
EclipseLink isn't called). There's no Exception or other error. The
update method is as follows:
EntityTransaction trx = getEntityManager().getTransaction();
trx.begin();
object = getEntityManager().merge(object);
getEntityManager().persist(object);
trx.commit();
This method works fine with other (non-abstract) entities. I don't have
any idea what's wrong with it.
Any hints are appreciated.
Ralf.
Re: Entity is not updated [message #1707353 is a reply to message #1707046] Thu, 03 September 2015 18:49 Go to previous messageGo to next message
Am 01.09.2015 um 21:39 schrieb Ralf Heydenreich:
> Hi all,
> trx.begin();
> trx.commit();
Ok, found it by myself. The problem was that "object" was a detached
entity. Now, if you simply "merge" this entity into persistence context
then no changes are recognized. Thus, you have to read (or refresh) the
object _before_ doing any changes to it and then you can update it.
That's all :-)
Ralf.
Re: Entity is not updated [message #1707416 is a reply to message #1707353] Fri, 04 September 2015 11:03 Go to previous message
If the object is detached, how was it initially read in? EclipseLink should handle the merge correctly, so if refresh is required in your situation, then it must be that your detached object is not as detached as you may think. The only way for this to occur that I can think of is if you read your object from the shared cache, as a read-only instances are not cloned and not meant to be used for changes. The read-only instance is used underneath merges to build the managed instance to merge into.
[Updated on: Fri, 04 September 2015 11:08] by Moderator
Previous Topic:Descriptor for class was not found in the project"
Next Topic:Hung threads
Current Time: Sat Jul 19 14:50:17 EDT 2025
Powered by FUDForum. Page generated in 0.36104 seconds
