Home » Eclipse Projects » e(fx)clipse » Using FXMLLoaderFactory to load an FXML with a controller in a different bundle
Using FXMLLoaderFactory to load an FXML with a controller in a different bundle [message #1706846] Mon, 31 August 2015 09:06 Go to next message
I am writing a utility that uses FXMLLoaderFactory to load an FXML and use dependency injection with the controller. (The reason behind this is that the FXML is loaded from a server and is not located inside the bundle.)
The issue that I am facing is:
javafx.fxml.LoadException:
	at javafx.fxml.FXMLLoader.constructLoadException(FXMLLoader.java:2605)
	at javafx.fxml.FXMLLoader.access$700(FXMLLoader.java:104)
	at javafx.fxml.FXMLLoader$ValueElement.processAttribute(FXMLLoader.java:918)
	at javafx.fxml.FXMLLoader$InstanceDeclarationElement.processAttribute(FXMLLoader.java:967)
	at javafx.fxml.FXMLLoader$Element.processStartElement(FXMLLoader.java:216)
	at javafx.fxml.FXMLLoader$ValueElement.processStartElement(FXMLLoader.java:740)
	at javafx.fxml.FXMLLoader.processStartElement(FXMLLoader.java:2711)
	at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2531)
	at javafx.fxml.FXMLLoader.load(FXMLLoader.java:2429)
	at org.eclipse.fx.osgi.util.OSGiFXMLLoader.loadWithController(OSGiFXMLLoader.java:440)
Caused by: java.lang.ClassNotFoundException: de.emsw.gosa.product.ega.controller.DokumenteController cannot be found by de.emsw.gosa.fx.util_1.0.0.qualifier
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:439)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:352)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:344)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
	at javafx.fxml.FXMLLoader$ValueElement.processAttribute(FXMLLoader.java:916)
	... 132 more
The reason is that the controller class is not in the same bundle with the utility class. Is it possible to set the class loader for FXMLLoaderFactory, so that it searches in a bundle that I can specify?
Thanks!
Christoph
Re: Using FXMLLoaderFactory to load an FXML with a controller in a different bundle [message #1706947 is a reply to message #1706846] Tue, 01 September 2015 03:18 Go to previous messageGo to next message
So I guess you better use InjectingFXMLLoader, not? FXMLLoaderFactory in
simply wrapping that one. Disadvantage you get a direct dependency on
IEclipseContext.
Tom
On 31.08.15 15:06, Christoph Keimel wrote:
> bundle.)
> javafx.fxml.LoadException: at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 132 more
> Thanks!
> Christoph
Re: Using FXMLLoaderFactory to load an FXML with a controller in a different bundle [message #1706965 is a reply to message #1706947] Tue, 01 September 2015 04:15 Go to previous message
Yeah, you are right. That gives me exactly what I need. Thanks!
Previous Topic:Please review new wiki page for errors
Next Topic:PerspectiveStack not visible
Current Time: Sun Jul 20 11:45:00 EDT 2025
Powered by FUDForum. Page generated in 0.03462 seconds
