Home » Eclipse Projects » Eclipse Scout » Initial Size of a Dialog
Initial Size of a Dialog [message #1706219] Tue, 25 August 2015 02:41 Go to next message
is it possible to set the initial size of a form opened as modal dialog?
The attachments show the initial size and the desired size of the dialog. Can I somehow set the size to the desired size as shown?
Peter
Re: Initial Size of a Dialog [message #1706229 is a reply to message #1706219] Tue, 25 August 2015 03:21 Go to previous messageGo to next message
I use Swing as a client. To set the initial size of a form I use one of the next methods:
1: Increase the number of columns on the form.
2: Set the width property of the mainbox.
Regards Bertin
Re: Initial Size of a Dialog [message #1706298 is a reply to message #1706229] Tue, 25 August 2015 09:55 Go to previous messageGo to next message
Hi Bertin,
Bertin Kiekebosch wrote on Tue, 25 August 2015 07:21
I dont want to change the number of columns, since this form is used as view somewhere else. And there its fine.
Which method are you calling? I can't find a setWidth() on the mainbox...
Thanks, Peter
Re: Initial Size of a Dialog [message #1706307 is a reply to message #1706298] Tue, 25 August 2015 10:52 Go to previous messageGo to next message
MainBox -> Advanced Properties -> Layout -> Width in Pixel (getConfiguredWidthInPixel())
MainBox -> Advanced Properties -> Layout -> Height in Pixel (getConfiguredHeightInPixel())
Re: Initial Size of a Dialog [message #1706347 is a reply to message #1706307] Wed, 26 August 2015 03:36 Go to previous messageGo to next message
Indeed, I'm not using a runtime method but use the Scout Object Properties editor at design time.
Re: Initial Size of a Dialog [message #1706774 is a reply to message #1706347] Mon, 31 August 2015 00:52 Go to previous message
HI, it worked. Thanks. Peter
Previous Topic:Active outline at startup
Next Topic:Upgrade to neon
Current Time: Sun Jul 20 11:46:34 EDT 2025
Powered by FUDForum. Page generated in 0.14059 seconds
